MonsterUI - Material Design | Optymalizacja wyglądu
Bartosz_M
Opis:
Moduł graficzny do Xposed Framework upodabniający Android'a 4.0.4 - 4.4.4 do Android'a 5.X.X poprzez modyfikację interfejsu użytkownika na Material UI.
Co się zmieni:
• Action bar themed to Lollipop style
-actionbar color changing color to AccentColor,
-hided app icon from actionbar,
-changed actionbar size to looke like from LP,
• Framework graphic
-buttons,
-switchers,
-seekbar,
-textfields,
-some icons and more.
• Material Design checkboxes with animation!
• Material Design radio buttons with animation!
• Holo Blue color is theme accent color now
-all objects based on this color will be now theme accent,
- text highlight is theme accent
- and more..
• Tabs with color accent text,
• Dialogs are modyfied to look like material designed but to fully port this framework changes are necessary but for now
- Dialog title text colro is color accent
- button layout, size and deleted divinders,
- BUTTON_POSITIVE text is now color accent
• Toasts, deleted list dividers, changed background colors and more.
•Lollipop styled statusbar
•Lollipop styled dialer
•Costumization options per app
..and many many more, see changelog in second post
Jak będzie wyglądać:
post-1-0-92951100-1430138040_thumb.pngpost-1-0-97970700-1430138042_thumb.pngpost-1-0-68005300-1430138044_thumb.pngpost-1-0-63581700-1430138045_thumb.png
LINKI:
http://repo.xposed.info/module/com.kuaq.monsterui
INSTALACJA:
1. ZAINSTALUJ XPOSED FRAMEWORK I AKTYWUJ GO (BEZ TEGO ANI DUDU :))
2. ZAINSTALUJ POWYŻSZY APK Z SEKCJI "POBIERZ" W XPOSED LUB Z KARTY SD, JAK WOLISZ....
3. AKTYWUJ MODUŁ W XPOSED FRAMEWORK
4. SKONFIGURUJ MONSTER UI I CIESZ SIĘ "ANDROIDEM 5.X.X" ;)
WYMAGANIA:
- ROOT
- ANDROID 4.0.3 - 4.4.4
- XPOSED FRAMEWORK
NIE PONOSZĘ ODPOWIEDZIALNOŚCI ZA WSZELKIE USZKODZENIA!
WSZYSTKO ROBISZ NA WŁASNĄ ODPOWIEDZIALNOŚĆ!
  • Lubię to 3
Android 4.0.4 Galaxy Trend soft hiszpański (ten najnowszy co był na sammobile) Xposed Framework wgrane, aktywowane i telefon zrestartowany :)
Można kogoś prosić by przeniosl temat do działu Xposed ?
to działa na romach aosp
Jak framework zaktualizowany, modul poprawnie aktywowany to w takim razie chyba nie bd dzialal na twoj telefon .. Poczekaj na pomoc innych ja na swoim telefonie tego nie sprawdze czy cos sie od ostatniego czasu nie zmienilo
@MultiGamer widocznie procesory MediaTeka nie są wspierane do końca przez xposed
@MultiGamer wyświetla że plik nie istnieje
Niestety na moim LG L7 II p710 jest napisane: Your LG device isn't fully supported. Raczej z tym nic nie mogę zrobić? Wymagania wszystkie spełniłem.
