[Samsung Galaxy Ace2][4.3.1][TeamCanjica] CyanogenMod 10.2 Galaxy Ace 2
Pawliniak
CyanogenMod 10.2 dla Samsung Galaxy Ace 2 ( GT-I8160 )
Instalacja:
  1. Pobieramy http://d-h.st/users/TeamCanjica/?fld_id=27062#files oraz http://goo.im/gapps
  2. Wrzucamy pliki na kartę pamięci
  3. Uruchamiamy telefon w trybie recovery
  4. Wipe Data / Factory Reset
  5. Wybieramy "Install the Zip from External Storage"
  6. CM zip file oraz GApps zip file
  7. Reboot to system
  8. Enjoy!
Informacje:
ROM OS Version: 4.3.x Jellybean
ROM Kernel: Linux 3.0.x
ROM Firmware Required: I8160XXMG2 (Recommended)
Based On: CyanogenMod
Spotykane błędy:
Strzałki pobierania/wysyłania podczas połączenia danych
Słaby GPS - fix by mikesz98 ( instalacja przez CWM )
Banding kolorów na softwareowym dekoderze - fix by PolishVodka Color_Banding ( instalacja przez CWM )
Changelog:
18/11 :
  • Stability FIX - No more random reboots - Thanks to percy-g2 and munjeni
  • Fixed Low-Incall - Thanks to h3llrais3r
  • Fixed bluetooth settings
  • Removed USBdisk
  • Enabled KSM - Improved RAM management
  • Adb in recovery is working now
  • Build power.montblanc.so from sources
  • Not mounting preload as swap anymore
12/11 :
  • Fix signal bar problems
10/11 :
  • Fix mic and sound problems from last version
  • RIL improvements
  • Faster screenshoot taking
  • Surfaceflinger improvements
  • Fstab updated - Fixed sdcard problems
  • Mounting preload as swap partition
  • Swipe recovery function
  • Fix blackscreen bugs on S6D27A1 driver
  • SELinux disabled ( enabled Audit only )
04/11 :
  • Fixed 2G/3G toggle - Thanks to Macław Team
  • Sound glitches should be fixed now
  • OndemandQ governor added
  • SIO and ZEN io schedulers
  • Fixed BT tethering
  • Build should be more stable
  • Problems for users with other screen driver should be resolved
  • Deleted buggy MultiWindow for now
31/10 :
  • Fixed CRT-Off Screen animation
  • Devices with other screen driver now shouldn't have problems with booting
  • Fixed Random Reboots (Maybe - need more tests)
29/10 :
  • Testing MultiWindow
27/10 :
  • No more chanches for broken internal storage
  • Updated RIL
26/10 :
  • Fixed Tearing
  • Fix Torch toggle in QuickSettings
  • Fixed Torch turning on delay
  • Disabled CRT-off because it is broken
  • Softkey vibrations - Thanks to @PolishVodka
  • Galaxy Ace II settings app
23/10 :
  • Initial Release
  • Lubię to 3
Bardzo dobrze działa ten rom.
Wgrałem go siostrze i jej sie nie zacina.. działa płynnie i szybko.
Polecam go...
ps. siostra nawet nie wie za ma custom ROM
Wielkie dzięki za error-log i dodatkowo za fixy ^^
Propsy dla Adma i polecę forum znajomym.
//edit: jest gdzieś jakiś swap do karty sd?
nigdzie nie mog znaleźć... mógłby ktoś coś takiego napisać?
proponuje aktualizacje tematu o changelogi 28.11 i instrukcje swapu ;)
Edytowane przez Pawliniak
Nie umieszczamy linków do innych for o podobnej tematyce z Polski.
Możesz napisać jakie masz recvoery ?
Masz w ogóle ClockWorkMod recvoery?
Zrób najlepiej zdjęcie.
Pozdrawiam
Android system recovery <3e> . Tylko tyle tam pisze :D
Zrobiłeś ROOT i Recvoery ?
roota nie robiłem i w sumie zadnego recovery nie instalowałem :D Jedyne co zrobiłem w tym telefonie to aktualizacja androida z 2.x.x na 4.1.2 przez samsung kies .
O kolego... to jak ty chcesz wgrać CM?
Jak nie masz custom recovery
to: http://forum.cyanogenmod.pl/index.php/topic/479-root-dla-ace2-android-jellybean/
i to: http://forum.cyanogenmod.pl/index.php/topic/1151-galaxy-ace-2-cwm-recovery-6-gt-i8160/
Potem możesz dokonywać metod wgrywania Romów
O kurde :D Nie miałęm nawet pojęcia , ze wymagany jest root i jakies inne recovery :D Wielkie dzięki za pomoc :) Pozdrawiam :)
A i mam jeszcze 1 takie ogólne pytanie : Czy ten rom będzie działał płynniej niż Android ktory teraz aktualnie posiadam ? (muli strasznie )
Edytowane przez NeoCM
