DusieK Opublikowano 21 Kwietnia 2016 Zgłoś Udostępnij Opublikowano 21 Kwietnia 2016 ROBISZ WSZYSTKO NA WŁASNĄ ODPOWIEDZIALNOŚĆ. NIKT Z FORUM I PO ZA NIM NIE ODPOWIADA ZA JAKIEKOLWIEK USZKODZENIE URZĄDZENIA Cechy Check with Change log each update of kernel there are lots of new work and features Updated the ramdisk to .236 Updated Kernel sources to .236 updated Twrp Recovery ( new build 3.0) Updated Philz recovery ( new built ) New updated Busybox integrated with init.d support GCC 5.2.1 Linaro toolchain Sound control Added Atheros wifi Finally a fully working Wifi ( fixed ) not by stock modules Fixed Memory leaks and battery optimized Support exFAT sdcard added and enabled Intelli-KSM ( patch from Doomlord and lot more ) Two-way stereo call recording Zram Driver support Force Fast charging support LZMA compression Support sound control driver init.d scripts supported IO schedulers ( Which are required and works good) CPU Governors ( Which are required and works good) CPU VDD control Thermel temperturing control Added Kcal color control RGB Multipliers (Polynomial Color Correction) Display Color Inversion (Inverse Gamma Correction) [patch by savoca] Comes with an app to control color Added HBM ( High Brightnesss mode ) [HBM is able to be simulated by applying higher current drain to back light LED] And many more not remebered Wymagania CWM/TWRP ROOT Odblokowany Bootloader Pliki do pobrania Kernel [TUTAJ] Instalacja: Robimy Backup (zalecane) Wchodzimy do Custom Recovery Flashujemy paczke z kernelem Reboot system Link XDA http://forum.xda-developers.com/sony-xperia-z1-compact/development/5-1-1-236-kryptonian-z1c-kernel-advanced-t3362556 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
