Wanam Kit
PatrzKomuUfaszGb
Ten modul jest kompatybilny z AOSP/ NEXUS/Google Edition (samsung, htc...)
Enable Numeric battery
Clock position (Right, Center, Left, Hide)
Change Color and Typeface of the Battery text
Disable Scrolling cache
Skip Music with Volume buttons
Disable screen turn ON while plunging or unplugging AC/USB cable
Disable loud volume sound warning
Advanced Power menu:
#reboot
#recovery
#hotboot
#screencapture
#screen recording (busybox)
#Quick Dial number (+ Display number)
#On/Off Data
Enable Data Roaming on home network only
Torch (Flashlight) Through Volume UP button
Long back kill App
CM Circle Battery
Expand all notifications
Add and option to kill all app activities (requires granting Root access to System user)
Enable Heads up notifications (Optional ongoing notifications and display delay customization)
Disable Swipe gestures (keep double tap) for the devices that support it.
Hide/Set Color of Battery Text
WYMAGANIA
Android 4.4 +
Xposed
Link do pobrania http://dl-xda.xposed.info/modules/ma.wanam.wanamkit_v151_cfe768.apk
