[Samsung Galaxy S3 LTE] Resurrection Remix® M 6.0.1
rafaln84
YM52HZc.thumb.png.0c30166c01eb3bf5720094
[Galaxy S III LTE][OFFICIAL] Resurrection Remix® M 6.0.1
Instrukcja Instalacji:
-Pobierz najświeższy build romu
- Pobierz gappsy
- Zrób kopię romu dotychczasowego jeśli chcesz
- Zalecane: Pełne wipe i factory reset
- Flash ROMu za pomocą custom recovery, np. CWM, Philz, TWRP...
- Flash gappsów
- Reboot
- Gotowe!
Instrukcja Aktualizacji:
- Pobierz najświeższy build romu
- Wipe cache
- Wipe dalvik cache
- Reboot
- Gotowe!
Screenshot_20160225-110223.thumb.png.697Screenshot_20160225-110307.thumb.png.ffbScreenshot_20160225-110355.thumb.png.649Screenshot_20160225-110417.thumb.png.350Screenshot_20160225-110437.thumb.png.7f2Screenshot_20160225-110508.thumb.png.a6aScreenshot_20160225-110535.thumb.png.401Screenshot_20160225-110545.thumb.png.933Screenshot_20160225-110558.thumb.png.f4dScreenshot_20160225-110607.thumb.png.2a4Screenshot_20160225-110614.thumb.png.0b8Screenshot_20160225-110651.thumb.png.856Screenshot_20160225-110705.thumb.png.b6dScreenshot_20160225-110903.thumb.png.1bc
Changelog:
Android Marshmallow 6.0.1_r10 > 6.0.1_r13
FWB: Status bar header font style
FWB: Even more fonts to LS clock
Hide Lockscreen clock & date
FWB: Notification Header Customizations
SystemUI : 3G Icon Instead Of H+ Switch
Custom header: Add shadow to more TextViews
QS: Selinux Switch Tile
QS: App picker Tile
RR logo Location
Breathing SMS
SystemUI: Double tap to sleep anywhere on the lock screen
NavBar: Add Some More Buttons [ camera,Screenshot,Kill Task, Pie,Torch,RR config,App picker, screenrecord, Immersive Mode]
SystemUI: HeadsUp whitelists
SystemUI: HeadsUp blacklists
HW keys tweaks
FBW: Add DancingScript / ComingSoon / NotoSerif to Statusbar Temp
FBW: Add DancingScript / ComingSoon / NotoSerif to Statusbar Clock
Make task manager button themeable
Hide arrows in network traffic indicators
Qs : Improve Navbar Tile Logic
SystemUI: handle when brightness slider is hidden
SystemUI: don't add already attached qs tile pages
SystemUI: smoother tile transitions when moving to 1st row
SystemUI: improve tile caching mechanism
Lockscreen fonts: set correct default value
Make lights out mode of navigation bar consistent to normal mode.
SettingsProvider : Don't replay aosp defaults every boot
aapt: add check for untranslatable "string array"s
pm: Fix ordering of parameters for sendPackageBroadcast.
allow priveleged phone state permission to be whitelisted
SystemUI: disable editing tiles while in lock screen
Clean Up QSpanel
SystemUI: make sure to expand all the way when flinging
SystemUI: initialize drag panel with proper column count
IMS: Add Ims reason info codes for supplementary service failures
IMS: Fix video call forwarding options issue
Add mapping string for call reject cause code 26.
SysUI: Listen for changes to LIVE_LOCK_SCREEN_ENABLED
SystemUI: Don't update if HeadsUp is disabled
Intent: Fix a NPE on readFromParcel
SettingsProvider: Add missing INTERACT_ACROSS_USERS_FULL permission
Taskmanager: Reduce Logging
Flip to Mute/Reject Call
SystemUI: add better hints when trying to delete edit tile
SeekBarVolumizer : Disable notification volume if RINGER_MODE_VIBRATE
Partially revert 'SOFTAP: implement SOFTAP new requirement in framewo
ZenMode : Update defaults for CTSVerifier
Tethering: Fix number of device connected
am: Don't take down activity process if target intent component is null.
Themes: Fix CMSetupWizard package name in ThemeService
Themes: def theme package is defined in CMSettings
Add keylayout for Xbox One controller
SystemUI: make online cpu color green for cpu overlay
Don't reuse weather controller before it's changed
Wifi tile: don't set items visible from non ui thread
SystemUI: fix contracting qs settings page
allow whitelisting of ACCESS_KEYGUARD_SECURE_STORAGE
SystemUI: visually disable EditTile in lock screen
add routing for explicit call transfer
Battery: Show battery fully charged notification
Fix pattern visibility settings
Alarm: add missing closedir after opendir when searching for RTC
String update, change wording from "Mobile" to "Cellular"
Frameworks: Restart last task if last task is dead
SystemUI: Allow clearing recents tasks within recents button
Frameworks: Lockscreen blur fix & tweak
fw: Make sure to get the actual ringtone uri per subId.
nms: Actually allow smsRingtone to work.
SystemUI : Show create profile if user doesn't have one setup
Tethering: Turn off Wi Fi Hotspot after inactivity
SELinuxTile: use runShellCommand instead of runSuCommand for getenforce
am: Handle potential NPE when activity info can't be resolved.
SystemUI: nuke broadcast tile from user tile list
base: fix window bounds for left hand navigationbar
SystemUI: add flashlight notification reminder
Themes: Process applied themes before boot finishes
Add FDN enabled related API
Themes: Get default theme from CMSettings
SysUI: Make sure LLS is enabled after inflation
Fix lockscreen disabling for MSIM.
SystemUI: update keyguard state when profiles disable keyguard
SystemUI: prompt for SIM PIN if lockscreen is disabled
systemui: notify everyone that lockscreen is not going to be shown
Profiles: Disable lock screen after boot
The DUT can't screen shot in guest mode
DocumentsUI: Expose appbar elevation value.
pm: Allow fall through for protected apps validator activity.
GlobalActions: Use circular user avatars
LiveDisplayTile : Update entries on locale changes
livedisplay: remove user hint notification when clicked
GlobalActions: Fix setting ringer mode in global actions
lights: Automatically generate an LED color for notifications
Remove leftover power menu profile resources
settings: Add preference for automagic LED colors
Settings: blacklist: update iconography
Fingerprint: do not error out when stopping to listen
ProtectedApps: add up navigation and fix action bar icons
All updates and Fixed From CM
Improved Translations
For More Info Track Github Acitivity
NOTE: DUE TO CMS TOYBOX CHANGES, SYSTEMUI RESTART HAS BEEN BROKEN. WE ARE TRYING TO FIX THIS ISSUE
Download
ROM: ResurrectionRemix-M-v5.6.3-20160209-i9305.zip: https://basketbuild.com/uploads/devs/resurrectionremix/i9305/ResurrectionRemix-M-v5.6.3-20160209-i9305.zip
GAPPS: http://mirror41.downloadandroidrom.com/download/gapps/6.0/BaNkS-Dynamic-GApps-6.x.x-10-20-15.zip?token=226832457 (Ja użyłem tych gappsów ale bez tez rom działa)
XDA: http://forum.xda-developers.com/galaxy-s3/development-i9305/rom-resurrection-remix-4-4-2-kitkat-v5-t2704828
Nowy build ResurrectionRemix-M-v5.6.4-20160223-i9305.zip  https://basketbuild.com/uploads/devs/resurrectionremix/i9305/ResurrectionRemix-M-v5.6.4-20160223-i9305.zip :)
Changelog:
i9305: Enable Button illumination/variable button brightness
i9305: Enable Hw Keys Overlay from Lollipop
Added back Multi Window feature
Stock GCC Toolchain used by default now
If maintainers want to use Uber or other custom toolchain, they can sync in local manifest
Reverted to AOSP Setup Wizard
RR Settings Categories organized
SystemUI: Show lockscreen wallpaper if no album art is available
QS: Show # of clients connected to hotspot
Revert "Frameworks: Slim Shortcuts"
LockScreen customization [color] improved.
cmsdk: insert dnd & edit tiles for 12.1 -> 13.0 upgrade
SystemUI: Prevent search bar flicker between recents and launchers
SoundRecorder: fix menu behavior on devices with hardware menu button
cmsdk: add common action for launching camera from screen gesture
Settings: add config to apply custom shadow on header images
Settings: daylight header packs extensions
Revert "Settings: Add option for new poly hd custom headers
Dashboard tileview dividers toggle
Add single & double tap option to mid-lockscreen shortcuts
cmsdk: add Sound tile to QS
Set number of tile columns
CMSDK:Hardware Keys Tile
Fix systemUI restart command
framework: Log applied theme when apps crash
Screen Pinning: Show correct text for on screen nav
SystemUI: disable QS tile Edit mode on screen off
Recents : Don't show clear all if no tasks
SystemUI:Improve task view header layout
Fixed Some Statusbar lags
Force OpenWeatherMap to be the weather provider
AppSideBar Reverted due to instability
SysUI: LiveLockScreen Updates from CM
Recents: Fix Clear All Button Disappearing Again
SystemUI: add caffeine qs tile
update secure keyguard check
Revert "DndTile: Always open the detailed view"
SystemUI: add volume tones back
Option for date style/position, left-right of clock
Return: Smart Pulldown And Enable By Default
Fix leftAffordanceView visibility bug
framework: move device key handler logic, fix gesture camera launch
Keyguard: Show backdrop when sim pin secure screen shown
Add rotation animation to navbar icons
Settings: Add notification light setting to system profiles
SimDialogActivity: Check whether there is no default sub
Kill App Tile
SystemUI: handle hiding recents search bar dynamically
Revert "SystemUI: Add option to disable search bar in recents
Notification Header Customization Colors
Device specific Updates
CM updates
Translations updated
Check GitHub commits for more.
O 7.03.2016o17:50, xedox6418 napisał:
  1. Mógłby ktos podać link skad i ktore gappsy pobrac do 5.6.4, wybaczcie, nie chce czegos spieprzyc  ... Juz zauwazylem
Po zainstalowaniu zauwazylem dwa problemy:
1.Przy podłączeniu do pc przez kabel usb znajduje telefon lecz przez zaden tryb nie chcą sie pokazac karty wewn. i sd
2.Inne aplikacje od aparatu nie chcą dzialac,tak samo aplikacje do tapet, bo trzeba wylaczyc nakladke ekranowa - da sie to wgl zrobic?
Mam nadzieje ze ktos pomoze ;)
1. Wystarczy, że zainstalujesz SuperBeam na telefonie i PC. Masz już jedno obejście.
Co do drugiego na razie nie znam rozwiązania jeszcze. Pogrzebię trochę u siebie i zobaczę czy mam cuś takiego u siebie.
Odpada przesył przez wifi (AirDroid do tego uzywam), gdyz czesto zgrywam przez kabel filmy itp od innych,więc,moze da sie cos na to poradzic?
Drug problem rozwiazany, apka Lux Auto Brightness okazala sie przyczyna, blokowala dostep niewiadomo czemu,a szkoda bo przydatna byla
Nowy build ResurrectionRemix-M-v5.6.5-20160311-i9305: https://basketbuild.com/uploads/devs/resurrectionremix/i9305/ResurrectionRemix-M-v5.6.5-20160311-i9305.zip
Changelog:
- Android 6.0.1_r13 -.6.0.1_r17
- Major Clean up & Fix to SystemUI. Memory Leak has been majorly fixed and Lags Have Been taken care of
- Fix 1st Boot stuck on "Preparing Contacts Storage"
- StatusBar Icon Colors
- Statusbar: Custom Logos and Styles
- Qs Custom Colors
- Recents Custom Clear All Styles
- Recents Panel Customizations
- Recents Clear All FAB animations
- QS/TM : Update task manager UI & add fab button
- More Lockscreen Colors
- Lockscreen Weather Colors
- Powermenu Torch option
- DU Pulse,Fling, Smartbar (Revert Cms navbar)
- Qs Vibrations
- Improve Navbar Tile
- Add Always QuickPullDown option
- Revert "Frameworks: Slim Shortcuts"
- Revert "Option to Set no of Qs Rows and Columns" (suspected to cause lag)
- New Qs Stock Icons
- Optional Dashboard switches
- Clock Color Switch
- Change No weather button as image button layout
- SysUI: Clear notification data when recreating status bar
- audiosystem: Add API for listening to effect session events
- sensors: Create bool to select what timestamp to use
- SystemUI: Add PERFORMANCE_ACCESS permission.
- base: Fix proximity check on non power key
- SysUI: Fix hiding sensitive notification behavior
- Allow to ignore presentation indicator of outgoing calls
- dock battery
- Revert "PhoneWindowManager: add ability to use EdgeGestureService
- intel: Pick the best ABI based on number of libs, not just priority
- NetworkPolicyManager : Process low power mode change on background thread
- Fix bottom shortcuts default icon tint color
- Frameworks: Fix hw menu key from unlocking on swipe
- Revert "Heads Up Timeout & Snooze 1/2"
- Settings: fix indexing for saved access point settings
- Settings: Fix SecuritySettings filtering.
- Fix selinux OnBoot settings crash on first boot
- Use correct icon for ring volume
- Themes: Expose Hard colors for storage settings
- All updates from CM
-For more info Track Github Activities
  • Pawliniak zmienił(a) tytuł na [Samsung Galaxy S3 LTE]OFFICIAL] Resurrection Remix® M 6.0.1
Nowy build ResurrectionRemix-M-v5.6.5-20160314-i9305.zip https://basketbuild.com/uploads/devs/resurrectionremix/i9305/ResurrectionRemix-M-v5.6.5-20160314-i9305.zip
Changelog:
- Android 6.0.1_r17 -.6.0.1_r22 / Changelog :
- http://www.androidpolice.com/android...changelog.html
-SystemUI: Optimizations and cleanups
-Add needed callbacks to refresh statusbar view and update contents
-clean up do not stress (recreate statusbar)
-Prevent to fix statusbar lag issues
-Revert pie control (deprecated and breaking things)
-Revert edge gesture service (deprecated and breaking things)
-Fix system ui NPE when device rotated
-Don't refresh ui when screen off
-Fixed lockscreen clock and date color not updating after disable refresh ui when screen is off
-Clean up scrollbars (deprecated)
https://plus.google.com/+varund7726/posts/Yrbc4sk3gyh
Download
ResurrectionRemix-M-v5.6.6-20160402-i9305.zip: https://basketbuild.com/uploads/devs/resurrectionremix/i9305/ResurrectionRemix-M-v5.6.6-20160402-i9305.zip
The Changelog
- SystemUI: Restart System UI on theme Change and NP color switch
- LLS: Add LiveLockScreenController
- Update RR logos
- SystemUI : Fix Network Traffic Colors Not updating
- SystemUI: Fix headsup stuck after theme change and recreate statusbar
- [SQUASHED]Mass Revert of CM's Qs Drag Panel
- FWBase : Port & Improve CPU boosting Hooks && Interface
- Fix headsup blacklist and whitelist
- SystemUI :[Squashed] Fixed Leaks and Observers
- SystemUI: Reduce Load On ContentObservers
- SystemUI: Optimizations and cleanups
- ix metrics density comparisons
- GlobalActions: Set the initial status of airplane mode toggle
- SystemUI: Change demo mode time of day.
- Prompt permission dialog for status bar weather
- Should use scan flag, or it will not scan device.
- base: pipe all IME hints regardless of IME notification state/settings
- SystemUI: Fix Notification panel NPE
- Qs: Improve Themes Tile
- [ThemesTile] Sort themes
- Port ThemesTile to new CMTE api
- Compile app theme in background
- Cast Tile: only scan while in detail view
- SystemUI: more consistent visualizer logic
- Fling : Gallery icon support
- camera2 legacy: Allow HDR processing to take a while
- Cleanup Ls Weather Layout
- Revert "MediaScanner behavior on boot
- Add Resurrection ringtone v2
- Hack to remove black bar on custom lockscreen wallpaper
- Themes: Fail theme install if common resources fail
- SystemUI: stop hiding hotspot & color inversion tiles
- For more info Track Github Activities
- Translations updates
