[Sony Xperia E(C1505)] Problem po odblokowaniu bootloadera
Pawel Palka
Witajcie Forumowicze, odblokowałem bootloader no i telefon się zapętlił, proóbowałem zainstalować firmware 11.3.a.2.33 ale niestety nie pomogło, co możecie poradzić? Dodam że próbowałem go naprawiać przez PC Companion ale nie widzi telefonu. Log z flashowania
02/001/2015 18:01:30 - INFO - Selected Bundle for Sony Xperia E (C1505). FW release : 11.3.A.2.33. Customization : CE 02/001/2015 18:01:30 - INFO - Preparing files for flashing 02/001/2015 18:01:36 - INFO - Please connect your device into flashmode. 02/001/2015 18:01:46 - INFO - Device connected in flash mode 02/001/2015 18:01:46 - INFO - Opening device for R/W 02/001/2015 18:01:46 - INFO - Reading device information 02/001/2015 18:01:46 - INFO - Phone ready for flashmode operations. 02/001/2015 18:01:46 - INFO - Opening TA partition 2 02/001/2015 18:01:46 - INFO - Current device : C1505 - - 1270-8755_R4E - 1267-9537_11.3.A.2.33 - WORLD-i_11.3.A.2.33 02/001/2015 18:01:46 - INFO - Closing TA partition 02/001/2015 18:01:46 - INFO - Start Flashing 02/001/2015 18:01:46 - INFO - Processing loader.sin 02/001/2015 18:01:46 - INFO - Checking header 02/001/2015 18:01:46 - INFO - Flashing data 02/001/2015 18:01:51 - INFO - Loader : S1_Root_a8a4 - Version : R5D030 / Boot version : R10D030 / Bootloader status : ROOTED 02/001/2015 18:01:51 - INFO - Max packet size set to 64K 02/001/2015 18:01:51 - INFO - Making a TA backup 02/001/2015 18:01:51 - INFO - Opening TA partition 1 02/001/2015 18:01:51 - INFO - Start Dumping TA partition 1 02/001/2015 18:01:51 - INFO - Finished Dumping TA partition 1 02/001/2015 18:01:51 - INFO - Closing TA partition 02/001/2015 18:01:51 - ERROR - 02/001/2015 18:01:51 - ERROR - Error dumping TA. Aborted 02/001/2015 18:01:51 - INFO - Opening TA partition 2 02/001/2015 18:01:52 - INFO - Start Dumping TA partition 2 02/001/2015 18:01:52 - INFO - Finished Dumping TA partition 2 02/001/2015 18:01:52 - INFO - TA partition 2 saved to C:\Users\palecka\.flashTool\registeredDevices\UNKNOWN\s1ta\2015-11-02_06-01-51\2.ta 02/001/2015 18:01:52 - INFO - Closing TA partition 02/001/2015 18:01:52 - INFO - No flash script found. Using 0.9.18 flash engine 02/001/2015 18:01:52 - INFO - Opening TA partition 2 02/001/2015 18:01:52 - INFO - Writing TA unit 00002774. Value : [01] 02/001/2015 18:01:52 - INFO - Closing TA partition 02/001/2015 18:01:52 - INFO - Processing partition-image.sin 02/001/2015 18:01:52 - INFO - Checking header 02/001/2015 18:01:52 - INFO - Flashing data 02/001/2015 18:01:53 - INFO - Opening TA partition 2 02/001/2015 18:01:53 - INFO - Closing TA partition 02/001/2015 18:01:53 - INFO - Opening TA partition 2 02/001/2015 18:01:53 - INFO - Processing amss.sin 02/001/2015 18:01:53 - INFO - Checking header 02/001/2015 18:01:53 - INFO - Flashing data 02/001/2015 18:01:59 - INFO - Processing amss_fsg.sin 02/001/2015 18:01:59 - INFO - Checking header 02/001/2015 18:01:59 - INFO - Flashing data 02/002/2015 18:02:00 - INFO - Processing cache.sin 02/002/2015 18:02:00 - INFO - Checking header 02/002/2015 18:02:00 - INFO - Flashing data 02/002/2015 18:02:01 - INFO - Processing fota0.sin 02/002/2015 18:02:01 - INFO - Checking header 02/002/2015 18:02:01 - INFO - Flashing data 02/002/2015 18:02:01 - INFO - Processing fota1.sin 02/002/2015 18:02:01 - INFO - Checking header 02/002/2015 18:02:01 - INFO - Flashing data 02/002/2015 18:02:02 - INFO - Processing kernel.sin 02/002/2015 18:02:02 - INFO - Checking header 02/002/2015 18:02:02 - INFO - Flashing data 02/002/2015 18:02:03 - INFO - Processing modem_fs1.sin 02/002/2015 18:02:03 - INFO - Checking header 02/002/2015 18:02:03 - INFO - Flashing data 02/002/2015 18:02:03 - INFO - Processing modem_fs2.sin 02/002/2015 18:02:03 - INFO - Checking header 02/002/2015 18:02:03 - INFO - Flashing data 02/002/2015 18:02:03 - INFO - Closing TA partition 02/002/2015 18:02:03 - INFO - Opening TA partition 2 02/002/2015 18:02:03 - INFO - Processing system.sin 02/002/2015 18:02:03 - INFO - Checking header 02/002/2015 18:02:03 - INFO - Flashing data 02/004/2015 18:04:00 - INFO - Closing TA partition 02/004/2015 18:04:00 - INFO - Opening TA partition 2 02/004/2015 18:04:01 - INFO - Flashing preset1.ta to partition 2 02/004/2015 18:04:01 - INFO - Writing TA unit 000008FD. Value : [00] 02/004/2015 18:04:01 - INFO - Writing TA unit 00000961. Value : [00, 00, 00, 00] 02/004/2015 18:04:01 - INFO - Closing TA partition 02/004/2015 18:04:01 - INFO - Opening TA partition 2 02/004/2015 18:04:01 - INFO - Processing elabel-C1505-row_201310181930.1_private.sin 02/004/2015 18:04:01 - INFO - Checking header 02/004/2015 18:04:01 - INFO - Flashing data 02/004/2015 18:04:04 - INFO - Closing TA partition 02/004/2015 18:04:04 - INFO - Opening TA partition 2 02/004/2015 18:04:04 - INFO - Writing TA unit 00002725. Value : [32, 30, 31, 35, 2D, 31, 31, 2D, 30, 32, 20, 31, 38, 3A, 30, 34, 3A, 30, 34, 00] 02/004/2015 18:04:04 - INFO - Writing TA unit 00002774. Value : [00] 02/004/2015 18:04:04 - INFO - Closing TA partition 02/004/2015 18:04:04 - INFO - Ending flash session 02/004/2015 18:04:04 - INFO - Flashing finished. 02/004/2015 18:04:04 - INFO - Please unplug and start your phone 02/004/2015 18:04:04 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings 02/004/2015 18:04:04 - INFO - Device connected in flash mode 02/005/2015 18:05:39 - INFO - Device disconnected 02/005/2015 18:05:43 - INFO - Device connected in flash mode 02/006/2015 18:06:26 - INFO - Device disconnected 02/006/2015 18:06:38 - INFO - Device connected with USB debugging off 02/006/2015 18:06:38 - INFO - For 2011 devices line, be sure you are not in MTP mode 02/006/2015 18:06:40 - INFO - Device disconnected 02/006/2015 18:06:49 - INFO - Device connected with USB debugging off 02/006/2015 18:06:49 - INFO - For 2011 devices line, be sure you are not in MTP mode 02/007/2015 18:07:36 - INFO - Device disconnected 02/007/2015 18:07:45 - INFO - Device connected with USB debugging off 02/007/2015 18:07:45 - INFO - For 2011 devices line, be sure you are not in MTP mode 02/008/2015 18:08:32 - INFO - Device disconnected 02/008/2015 18:08:41 - INFO - Device connected with USB debugging off 02/008/2015 18:08:41 - INFO - For 2011 devices line, be sure you are not in MTP mode 02/009/2015 18:09:28 - INFO - Device disconnected 02/009/2015 18:09:38 - INFO - Device connected with USB debugging off 02/009/2015 18:09:38 - INFO - For 2011 devices line, be sure you are not in MTP mode 02/010/2015 18:10:24 - INFO - Device disconnected
Częściowo sobie poradziłem, prawdopodobnie powodem był nie oryginalny kabel, bądź to że nie potrzebnie utowrzyłem folder w Flashtool.
1 odpowiedź na to pytanie
Kabel USB nie ma nic do rzeczy.
Nowe wersje flashtoola mają jakieś problemy z flashowaniem.
Dlatego zaleca się używanie starszych.
Odblokowany bootloader też nie na nic do rzeczy.
Co więcej po odblokowaniu bootloadera zaleca się wgranie czystego stocka.
Przynajmniej ja tak zawsze robię i problemu żadnego nie ma.
Dopiero potem dograłem custom kernel w Xperii E.
Jak ją robiłem ponad 3 miesiące temu
