jankessster Opublikowano 16 Września 2014 Zgłoś Udostępnij Opublikowano 16 Września 2014 ROM bazuje na oryginalnym 4.0.4. Działa nawet na zablokowanym bootloaderze!!Od autora Xperia Ultimate HD is and will always be a free custom ROM, which greatly extends the capabilities of your phone. Ultimate HD gives you higher performance, a blazing fast user interface and a great battery life. And you can't just enjoy gaming, browsing and chatting more - with the latest aftermarket fixes your phone is more save, and your protected better than with any other ROM. It features a brand new redesigned UI, many new themes and features, and thousands of internal improvements for a more convenient and intuitive control. Do what you want - faster and easier, and better looking. Its constantly beeing improved, and the dev team is listening to requests by YOU. Try it now - you won't regret it.Co takiego ma Xperia Ultimade HD Based on ICS- Slim & Lightweight- AROMA Installer for convenient installation- Supporting many devices: Xperia arc, Xperia arc S, Xperia Pro, Xperia Neo, Xperia Neo V, Xperia Ray, Xperia Mini*, Xperia Mini Pro*, Xperia LWW*- Redesigned framework with transparent elements and 7 unique and beautiful themes- Support application for beginners- Reboot menu- Disabled data-traffic message- Onscreenbuttons (can be disabled with 1 click)- Advanced Install Manager- New Walkman, Movies and Album application- Cybershot camera for better pictures than ever - with superior auto- New Lockscreens available to choose in Aroma Installer- New Clock Application and Widget- Faster and easier wheaterwidget- New Launchers (XZ/XT)- New calculator application- New Calculator and Email app- Redesigned widgets- New easteregg- Patched core.jar for more security- Notification LED working (***)- 2G/3G Reboot bugfix (***)- Ultimate HD advanced section- Supersmooth UI and blazing fast gaming- Busyboxed and prerooted- Full INIT.D** & CWM support- Many updated apps- All apps are zipaliged and optimized- Updated GPU and hardware driver- Project Butter- VM & RAM Tweaks- UI Tweaks- Updated Icons and UI- New "Notes" Application and new keyboard for easy writing- Tweaked Camera and updated libs- Xperia Z Statusbardesign- Support for Multi-Languages*MDPI Devices, port available by stanlin salu and sandy7** may be kernel related*** sony bugs, fixed in this romXperia Ultimate HD Advanced Settings:- CPU Control- Statusbar Settings- Navigation Softkeys- GreenifyAROMA Installer:System:- First Install/Upgrade- Launcher- Device- Bootanimation- Lockscreen- ROM Engine- Unlocked/Locked BootloaderApps and Mods:- Button Backlight- Sony Car- ANT+- Gmail- XDA- File Explorer- Walkmantu go pobierz http://forum.xda-developers.com/showpost.php?p=46206072&postcount=15775Instalacja For Unlocked Bootloaders: Flash any Kernel for stock ICS.For Locked Bootloaders: Root your phone using this tutorial, than install CWM using this appPlace ROM on SD-CardBack up user apps and data. (Various apps available, search Google Play. This is a popular one)Power off phone.Boot to CWM (Keep pressing the Volume Down key after the Sony logo appears)Wipe Data/Factory ResetMounts and Storage --> Format /System /DataAdvanced > Wipe Battery StatsInstall zip from SD card > Choose Xperia Ultimate HDFollow on screen instructions on AROMA.After Complete Installation untick "reboot" and select reboot in CWMGive the phone a good full charge, and enjoy your brand new phone!Linki: root zablokowanego bootloadera http://forum.xda-developers.com/showthread.php?t=1683957cwm na zablokowany bootloader https://play.google.com/store/apps/details?id=com.pvy.CWMinstaler Zdjęcia 1 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
