[Sony Xperia J] ROOTowanie urządzenia
  • 7 miesięcy temu...
  • 2 miesiące temu...
  • 5 tygodni później...
U mnie nie działa :/ cały czas coś takiego :
Device detected: ST26i (11.2.A.0.31)Attempt perf_swevent exploit...writing address is 8e49Error File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflowError File table overflow--- cleaningerror: device not found--- Please wait device is now rebootingerror: device not foundALL DONE!!!Aby kontynuować, naciśnij dowolny klawisz . . .
  • 3 miesiące temu...
Device type:
1) Normal
2) Special (for example: Sony Tablet S, Medion Lifetab)
x) Unroot
Make a choice: 1
Checking if i should run in Normal Mode or special Sony Mode
Please connect your device with USB-Debugging enabled now
remote object '/system/app/Backup-Restore.apk' does not exist
remote object '/system/bin/ric' does not exist
Normal Mode enabled!
Pushing busybox....
3881 KB/s (1085140 bytes in 0.273s)
Pushing su binary ....
3207 KB/s (91980 bytes in 0.028s)
Pushing Superuser app
3940 KB/s (996704 bytes in 0.247s)
Making busybox runable ...
Please look at your device and click RESTORE!
If all is successful i will tell you, if not this shell will run forever.
Running ...
Successful, going to reboot your device in 10 seconds!
Waiting for device to show up again....
Going to copy files to it's place
**mount: permission denied (are you root?)**
You can close all open command-prompts now!
After reboot all is done! Have fun!
Bin4ry
Press any key to continue . . .
Co to oznacza? Bo roota nadal nie mam, a nie wiem jak inaczej zrobić root :|
