[Samsung Galaxy S3 LTE] [PitchBlack] Resurrection Remix® LP 5.1.1
[Galaxy S3 LTE] [PitchBlack] Resurrection Remix® LP 5.1.1
yIZy9Xg.jpg.4d3e2b314ec1aacacf96617d8ebb
Moim zdaniem jest to najlepsza modyfikacja CM 12.1 z dostępnych na rynku.
  • ROOT
  • CWM/TWRP Recovery
Cytuj
-Dark Material Theme
-Quick-Smart Pulldown
-Buttons
-Battery mods
-Heads up
-Lockscreen Shortcuts
-Perfomance Profiles
-Ambiant Display
-ClockColor options
-Statusbar clock customization + second + fonts
-Network traffic monitor
-Toast animations
-Add changelog
-Listview animations
-Navigation bar dimensions
-Add Weather display to status bar header
-Quick unlock
-Overall Speed up system
-Amazing Battery Life
-Brand new music and audio fx app from cyanogen
-Included all cm 12 features
-And MORE..
Screenshot_2015-12-16-11-38-22.thumb.pngScreenshot_2015-12-16-11-38-39.thumb.pngScreenshot_2015-12-16-11-38-52.thumb.pngScreenshot_2015-12-16-11-41-34.thumb.pngScreenshot_2015-12-16-11-42-04.thumb.png
Instrukcja:
  1. Pobierz ROM i Gapps
  2. Wrzuć pliki na kartę pamięci
  3. Uruchom telefon w trybie recovery
  4. Wykonaj pełne WIPE,
  5. Zainstaluj ROM, potem Gapps
  6. Reboot
Pobierz:
ROM: https://www.androidfilehost.com/?w=files&flid=23080
Gapps: http://cyanmod.pl/gapps
xda: http://forum.xda-developers.com/galaxy-s3/development-i9305/rom-resurrection-remix-4-4-2-kitkat-v5-t2704828
Pojawiła się wersja Resurrection Remix® M v5.6.3
Changelog:
Android Marshmallow 6.0.1_r10 > 6.0.1_r13
FWB: Status bar header font style
FWB: Even more fonts to LS clock
Hide Lockscreen clock & date
FWB: Notification Header Customizations
SystemUI : 3G Icon Instead Of H+ Switch
Custom header: Add shadow to more TextViews
QS: Selinux Switch Tile
QS: App picker Tile
RR logo Location
Breathing SMS
SystemUI: Double tap to sleep anywhere on the lock screen
NavBar: Add Some More Buttons [ camera,Screenshot,Kill Task, Pie,Torch,RR config,App picker, screenrecord, Immersive Mode]
SystemUI: HeadsUp whitelists
SystemUI: HeadsUp blacklists
HW keys tweaks
FBW: Add DancingScript / ComingSoon / NotoSerif to Statusbar Temp
FBW: Add DancingScript / ComingSoon / NotoSerif to Statusbar Clock
Make task manager button themeable
Hide arrows in network traffic indicators
Qs : Improve Navbar Tile Logic
SystemUI: handle when brightness slider is hidden
SystemUI: don't add already attached qs tile pages
SystemUI: smoother tile transitions when moving to 1st row
SystemUI: improve tile caching mechanism
Lockscreen fonts: set correct default value
Make lights out mode of navigation bar consistent to normal mode.
SettingsProvider : Don't replay aosp defaults every boot
aapt: add check for untranslatable "string array"s
pm: Fix ordering of parameters for sendPackageBroadcast.
allow priveleged phone state permission to be whitelisted
SystemUI: disable editing tiles while in lock screen
Clean Up QSpanel
SystemUI: make sure to expand all the way when flinging
SystemUI: initialize drag panel with proper column count
IMS: Add Ims reason info codes for supplementary service failures
IMS: Fix video call forwarding options issue
Add mapping string for call reject cause code 26.
SysUI: Listen for changes to LIVE_LOCK_SCREEN_ENABLED
SystemUI: Don't update if HeadsUp is disabled
Intent: Fix a NPE on readFromParcel
SettingsProvider: Add missing INTERACT_ACROSS_USERS_FULL permission
Taskmanager: Reduce Logging
Flip to Mute/Reject Call
SystemUI: add better hints when trying to delete edit tile
SeekBarVolumizer : Disable notification volume if RINGER_MODE_VIBRATE
Partially revert 'SOFTAP: implement SOFTAP new requirement in framewo
ZenMode : Update defaults for CTSVerifier
Tethering: Fix number of device connected
am: Don't take down activity process if target intent component is null.
Themes: Fix CMSetupWizard package name in ThemeService
Themes: def theme package is defined in CMSettings
Add keylayout for Xbox One controller
SystemUI: make online cpu color green for cpu overlay
Don't reuse weather controller before it's changed
Wifi tile: don't set items visible from non ui thread
SystemUI: fix contracting qs settings page
allow whitelisting of ACCESS_KEYGUARD_SECURE_STORAGE
SystemUI: visually disable EditTile in lock screen
add routing for explicit call transfer
Battery: Show battery fully charged notification
Fix pattern visibility settings
Alarm: add missing closedir after opendir when searching for RTC
String update, change wording from "Mobile" to "Cellular"
Frameworks: Restart last task if last task is dead
SystemUI: Allow clearing recents tasks within recents button
Frameworks: Lockscreen blur fix & tweak
fw: Make sure to get the actual ringtone uri per subId.
nms: Actually allow smsRingtone to work.
SystemUI : Show create profile if user doesn't have one setup
Tethering: Turn off Wi Fi Hotspot after inactivity
SELinuxTile: use runShellCommand instead of runSuCommand for getenforce
am: Handle potential NPE when activity info can't be resolved.
SystemUI: nuke broadcast tile from user tile list
base: fix window bounds for left hand navigationbar
SystemUI: add flashlight notification reminder
Themes: Process applied themes before boot finishes
Add FDN enabled related API
Themes: Get default theme from CMSettings
SysUI: Make sure LLS is enabled after inflation
Fix lockscreen disabling for MSIM.
SystemUI: update keyguard state when profiles disable keyguard
SystemUI: prompt for SIM PIN if lockscreen is disabled
systemui: notify everyone that lockscreen is not going to be shown
Profiles: Disable lock screen after boot
The DUT can't screen shot in guest mode
DocumentsUI: Expose appbar elevation value.
pm: Allow fall through for protected apps validator activity.
GlobalActions: Use circular user avatars
LiveDisplayTile : Update entries on locale changes
livedisplay: remove user hint notification when clicked
GlobalActions: Fix setting ringer mode in global actions
lights: Automatically generate an LED color for notifications
Remove leftover power menu profile resources
settings: Add preference for automagic LED colors
Settings: blacklist: update iconography
Fingerprint: do not error out when stopping to listen
ProtectedApps: add up navigation and fix action bar icons
All updates and Fixed From CM
Improved Translations
For More Info Track Github Acitivity
NOTE: DUE TO CMS TOYBOX CHANGES, SYSTEMUI RESTART HAS BEEN BROKEN. WE ARE TRYING TO FIX THIS ISSUE
https://basketbuild.com/filedl/devs?dev=resurrectionremix&dl=resurrectionremix/i9305/ResurrectionRemix-M-v5.6.3-20160209-i9305.zip
  • Pawliniak zmienił(a) tytuł na [Samsung Galaxy S3 LTE] [PitchBlack] Resurrection Remix® LP 5.1.1
