[Nexus 5X] ★ Pure Nexus Project ★ Layers | Fi | WFC | VoLTE ★ 6.0.1
Zmiany:
Cytuj
-General
*Based on AOSP Android 6.0_r26
*Pre-rooted with SuperSU 2.52
*SELinux Enforcing
*Busybox
*Init.d support
*Addon.d support
*T-Mobile US WiFi Calling + Project Fi Support
*Fully Working VoLTE
*Native Sprint PRL/Profile update
*Full Layers 4.0 support
*Google sounds from factory image not the horrible AOSP ones
*Googles marshmallow wallpapers added to wallpaper picker
*Advanced Reboot menu enabled by default
*Advanced rotation settings
*Enabled Developer settings by default
*Enabled SystemUI tuner by default
*Enabled option to use multi-window mode
*Enabled click/longclick on notification panel header items
*Disabled forced encryption
*Disabled Device modification warning
*Disabled Tethering checks
*Disabled Full screen keyboard in landscape
*Show apps being optimized during initial boot
*Bug fix's and stability improvements
*UI Improvements (fixed a bunch google forgot to materialize)
*Download Speed in download notifications
*Scrolling cache improvements
*Seek-bar animation speed and font size control
*Hostname customization
*Adb over wifi access
*Full 3-Minit battery support no mods needed
*Kitkat style silent mode is now default
*Added ability to see app version when sideloading app
*Added ability to launch app from app info sceen
*Added app package name to app info screen
*Native Dialer lookup in the aosp dialer
*Incall vibration options
*National Data roaming option
*Link/Unlink Notification ringtone option
*Added Standalone documents ui file manager
*Added Special keys to all keyboard keys
*Added more smileys to the aosp keyboard
*Removed googles bug report option
*Removed googles SystemUpdate option
*Removed googles legal information
-PureNexus Settings
Lock Screen
*Option to customize lockscreen shortcuts
*double tap anywhere to sleep
*Option to disable lockscreen media art
*Scramble pin layout
*Quick unlock
*Lockscreeen Wallpaper (add/crop/delete)
Notification Drawer
*Weather
*Force Expanded Notifications
*quick settings pulldown (left,right)
*brightness slider on/off toggle
Recent Apps
*Recent app full screen mode
*Clear all recents toggle
*Clear all recents location option
*Clear all recents but last app toggle
*Recent searchbar on/off toggle
Statusbar
*Battery customization (stock, landscape, circle, dotted circle, text, none)
*Battery percent options (hidden, inside the icon, next to the icon)
*Battery Bar options (location, color, style, thickness, anitmation)
*Carrier Text customization (text placement, custom text)
*Clock customization (position, am/pm, date, date style, date format)
*Network traffic meter options (disabled/incoming/outgoing/both,  units displayed, update interval, autohide, autohidethreshold)
*Status-bar options (double-tap to sleep, statusbar brightness control)
Navigation Bar
*Enable/disable
*IME toggle
*Option for arrow cursor keys
*Option for double tap navbar to sleep
*Long-press back to kill toggle
*Long-press recents for last app toggle
*Navigation bar size customization (width, height, length)
*Navigation bar customization (placement, buttons)
PowerMenu
*Option to disable on secure lock
*Add/remove (reboot, screenshot, screen-record, airplane mode, user switcher,settings shortcut, search, voice search, lock now, sound panel)
Volume Rocker
*Volume key wake
*Volume key music control
*Volume key keyboard cursor control
*Volume button swap toggle
*Control media volume anytime toggle
*Option to allow volume down in silent to enter do not disturb
*Option to allow volume up in do not disturb to exit do not disturb
Display
*LCD density control
*Expanded desktop options
*option to enable/disable wake on plug
*LED controls
Notifications
*option to disable low battery notification
*Option to disable battery saver notification
cLock Settings
*Customize the cLock widget
Tools and info
*device info
*battery history
*usage statistics
*wifi info
*build.prop editor
*fi switch tools (if project fi sim is installed)
  • Odblokowany bootloader
  • TWRP Recovery 2.8.X.X
  • ROOT
Instrukcja:
  1. Pobieramy ROM i Gapps
  2. Wrzucamy pliki na kartę pamięci, na pamięć SD
  3. Przechodzmy w tryb recovery
  4. Wykonujemy pełne wipe systemu
  5. Instalujemy ROM, potem Gapps
  6. Reboot
Pobierz:
Rom Builds: https://www.androidfilehost.com/?w=files&flid=43154
Highly Suggested Gapps - PureNexus Gapps: https://www.androidfilehost.com/?fid=24269982087014833
Google Dialer for Fi Support: https://www.androidfilehost.com/?fid=24269982087014898
Flashable Vendors: https://www.androidfilehost.com/?w=files&flid=43558
xda: http://forum.xda-developers.com/nexus-5x/development/rom-pure-nexus-layers-fi-wifi-calling-t3244601
