[Samsung Galaxy S6 Edge][5.1.1] CrissCross Rom V6 and Stuff V6.2
DaRkShAdOw
ZARÓWNO JA JAK I CAŁE FORUM NIE PONOSIMY ODPOWIEDZIALNOŚCI ZA BRICK URZĄDZENIA ETC. WSZYSTKO ROBISZ NA WŁASNĄ ODPOWIEDZIALNOŚĆ!
CrissCross ROM
post-25555-0-50006400-1444562979_thumb.j
  Pokaż ukrytą zawartość
CRISSCROSS ROM V6.0
Changelog V6:
- Add init.d SQlite Optimizing database of apps (thanks to my friend @slaid480)
- Add init.d Fstrim Optimizing system files (thanks to my friend @slaid480)
- Volume warning remove (maybe will appear 1 time only)
- Fix data toggle warning remove
- Add Tweaks for better battery life (hope help a little bit )
- Update Quickconnect
- Updated Ant apps
- No wipes need it if you are coming from any previous version
- If you have Xposed Framework installed in version before, flash Xposed direct after rom installation without reboot between
BASED ON:
Phone Samsung Galaxy S6 edge
Model SM-G925F
PDA Version G925FXXU2COI1
CSC Version G925FOXX2COH3
PHONE Version G925FXXU2COH2
Region XEO
Country Poland
Build Date 07.09.2015
Changelist 5758468
OS Lollipop
OS Version 5.1.1
BASED ON:
Model SM-G925F
Region XEO
Country Poland
Changelist 5758468
OS Lollipop
OS Version 5.1.1
- Data toggle warning remove
- Init.d SQlite Optimizing database of apps (thanks to my friend @slaid480)
- Init.d Fstrim Optimizing system files (thanks to my friend @slaid480)
- Edit init.d support to fix the battery drain on some models
- Based on Crash Rom (Thx @Crash )
- Works on S6 / S6 Edge F/FD/I/T/K/L/S
- Aroma Installer with wipe option
- Deodex
- Private mode fix
- Samsung theme pack
- Pre Rooted
- 5 Way reboot menu
- Universal Model Support 920/925
- Multi Language
- Animations as default on 0.5
- Unibase Kernel
- Tweaks for battery, speed, cleaning logs and more without compromise daily use!
- Removed from the rom all the Google bloatware, FB, Whatsapp, Skype ... you can download from Play store.
- Stock Themed
- Knox free
- CSC Tweaks
- init.d support
- CallRec
- Keyboard Symbols
STUFF FEATURES:
Quote:
CRISSCROSS STUFF V6.2
Changelog V6.2
- Add 42 bootsplashes (thx @stangdriver)
- Make all statusbar icons in statusbars 100% bright (original 74%)
- Fixed bootsplash bug
- Aroma optimation for faster choosing (you didnt must scroll through every setting)
Changelog V6.1
- Add statusbar with left wifi and data, 3MinitBattery and centerclock
- Add 1 wifi icon
- Add 2 signal icons
- Add option to choose bootsplash (4 options)
Changelog V6
- Updated BetterBatteryStats to 2.1.0.0 RC2
- Updated EsExplorer to newer version
- Add working Netflix fix
- Add Dolby Mod with Viper4
Viper4
In case that you have problem with viper unistall the drivers and re installed again, to have full benefits viper you have to set FX Compatible Mode to "Normal" to check this open viper settings and go to FX Compatible Mode..
Dolby
Special thanks to @aki_007
And my friend @Arrow for share
Open Dolby app and by doble click on any preset you can config more options.
Bloat and Debloat
- Option to remove bloatware app by app
- Option to add bloatware app by app
Model Variant Choices
- Option to install/remove Edge features
- Option to install Dual Sim support
- Option to install Multi-Tasking tweak FHA - If don´t know what is read here
- Option to install NFC Mod (NFC works if screen off and locked)
- Option to install/remove Toolbox floating feature
- Option to activate all toggles
Additional Apps
- AdWare
- ES FileExplorer(Root)
- Dolby Mod with Viper4
- BetterBatteryStats
- OGYouTubeDownloader
- PhoneInfo
Kernel
- Option to choose between three different Kernel Profiles
Frameworks
- Option to add/remove Alliance Framework 3.1
Statusbars
- Option to install different statusbars with and without 3MinitBattery
- Option to install different statusbars with and without removed data toggle off warning
- Option to install statusbar with 3MinitBattery for Alliance Framework
Theme Statusbar Icons
- Signal icon (51 options) (if you use Alliance you must choose stock signal icon and 4 bars in settings)
- Data icon
- Wifi icon (36 options)
- Wifi/Data arrows
- GPS icon
- Alarm icon
- Toggle Background (only for Alliance Framework, You must choose there glass toggle background style and white circle color of toggle in Alliance settings)
- Bluetooth icon
Boot and Shutdown Animations
- Option to add bootanimation from 31 boot animations
- Option to add shutdownanimation from 25 shutdown animations
Rom Mods
- Option to enable/disable boot sound
- Option to add/remove extra fonts SamsungSans Fontpack by @Winb33 to 1032 Fonts (29.09.2015)
- Option to add/remove fix for Google Play Service battery drain
- Option to add and remove subsymbols and exit pop up in browser
- Option to choose between original or modded touchwiz launcher (5x5 appdrawer/app open-close animation/hidden settings)
- Option to add and remove volume boost
- Option to add netflix fix
Bootsplashes
- Option to choose bootsplash (46 options)
ROM
Aktualizacja
Musisz mieć bootloader z Androida 5.1.1
1. Zrób pełne wipe
2. Sflashuj ROM przez TWRP
3. Reboot
4. Opcjonalnie- zainstaluj aktualizację
5. Reboot
  • Lubię to 3
