DaRkShAdOw Opublikowano 11 Października 2015 Zgłoś Udostępnij Opublikowano 11 Października 2015 ZARÓWNO JA JAK I CAŁE FORUM NIE PONOSIMY ODPOWIEDZIALNOŚCI ZA BRICK URZĄDZENIA ETC. WSZYSTKO ROBISZ NA WŁASNĄ ODPOWIEDZIALNOŚĆ! Pure Nexus*Based on AOSP Android 5.1.1_r12(includes all the fixes from r13)*Lollipop sounds from factory image not the horrible AOSP ones*WiFi Calling + Project Fi Support!!*Native Sprint PRL/Profile update!!*Disabled forced encryption*Bug fix's and stability improvements*FULL Layers 2.1+ compatibility*Pre-rooted*Busybox*Init.d support*Addon.d support*Ui Improvements*Adb over WiFi*Host name customization*Phone number lookup*incall vibration features*Enable all files over Bluetooth*USB otg support*Fully working CAF AppOps*Developer settings enabled by default*Seek-bar animation speed and font size control*Completely killed bug report options*Custom LCD density control*Link/UnLink notification/ringer volume*Allow alarm in None mode "aka silent mode"*Enable/disable LEDs in None mode "aka silent mode"*allow volume keys to trigger no interruption mode (same way silent used to be)*Expandable volume control*Increased Media volume control from 15 steps to 30*Added Special keys to all keyboard keys*Added Spell checking for additional languages*Enhanced screen pinning*Launcher3 options (grid size, default homescreen, Enable/disable searchbar)*Lock screen notification control on per-app basis*Advanced rotation settingsCustom SettingsLock Screen*Customizable shortcuts*Double tap anywhere to sleep*Longpress lock icon on lockscreen for torch*Quick unlock*Scramble pin layout*Option to disable media cover art*Lockscreeen Wallpaper (add/crop/delete)Notification Drawer*Quick Pulldown*Smart Pulldown*Weather*Force Expanded Notifications*Custom Quick Setting Tiles (WiFi, Bluetooth, lte, data, sync, airplane, rotation, flashlight, location, NFC, notification, timeout, adb, cast, color inversion, compass, hotspot, batterysaver, headsup, power button, brightness, expanded desktop)*Quick settings options (enlarge first row, show four tiles per row, brightness slider toggle, advanced location settings, disable on secure lockscreen)Recent Apps*Recent longpress last app toggle*only show running apps toggle*AOSP Recents (search bar on/off, clear all button, clear all location, clear all minus foreground)*Slim Recents (enable/disable, show topmost task, show on left, expanded mode, max apps, panel size, panel color, card color, text color)Statusbar*Battery customization (stock, landscape, circle, dotted circle, text, none)*Battery percent options (hidden, inside the icon, next to the icon)*Battery icon color option*Battery Bar options (location, color, style, thickness, animation)*Carrier label customization (location, text, color)*Battery notification options (disable low battery notification, disable battery saver notification)*Clock customization (on/off, color, alignment, am/pm, date, date style, date position, date format)*Network Indicator Customization (on/off, color, display unit, update interval, auto hide, auto hide threshold*Statusbar icon options (enable/disable alarm/blue-tooth icon, color wifi/vpn icon, color signal/data icon, color airplane mode icon, color system icons)*Status-bar options (double-tap to sleep, brightness control, notification count)Navigation Bar*Enable/disable*Left handed mode*Arrow keys*IME toggle*Long-press back to kill*Double-tap to sleep*Enable/disable navigation rings*Navkey color option*Navigation bar size customization (width, height, length*Custimize navbar buttons/layout*Customize navbar circlesPowerMenu*Option to disable on secure lock*Add/remove (reboot, screenshot, screen-record, airplane mode, user switcher,settings shortcut, lock now, sound panel)Volume Rocker*Volume adjustment sound toggle*Volume keys control media volume*Volume key wake*Volume key music control*Volume button swap*Volunne key keyboard cursor controlApp Ops*Custom permission controlDisplay Settings*LCD Density*Expanded Desktop*Wake on plug*Notification LEDs*Battery LEDsNotifications/Media*Heads up customizations (on/off, blacklist, do not disturb, custom timeout, swipe left to dismiss, swipe right to hide)*Notification ticker text*Less frequent notification sounds*Camera shutter sound*Prevent audio ducking*Screen recorder optionscLock Settings*Customize the cLock widgetBuildy romuGapps(wybierz Gapps do CM12.1)Najlepsze Gapps do tego romuGoogle Dialer1. Wejdź do recovery2. Zrób wipe data i cache3. Zainstaluj ROM i gapps4. RebootWideo: 3 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
