[Nexus 6] Android M JDK 1.0 MPZ44Q
Jest to rom dedykowany dla Nexus-a 6, jak nazwa sugieruje najnowszego systemu android czyli M
Wersja wczesnorozwojowa!!
  • odblokowany bootloader
  • ROOT
  • CWM/ TWRP najnowsze
Lista zmian :
1.0.11 (md5: f3440419d4da8ae0d84a6a258e9b406b)
fixed issue with wifi disconnecting randomly in some cases
another small tweak to help performance issues in games
cleaned up some tweaks even more
better hand off between wifi and cell signal
1.0.10 (md5: d47b7e32ff64b91fd8fb17f4a61c0feb)
added version number to build number in about screen (also out of preview builds!)
fixed other issues causing lag in games (remaining lag will need to be fixed by Google, it was introduced in the M)
added tethering fix for t-mobile users
fixed issue with memory management
further improved overall performance
added default viper settings for users with issues out of the box
1.0 p9 (md5: 8eb2aeaff5a6fecad6a8d28b46ca948b)
fixed issue causing gpu to throttle (need to make one more change for optimal performance)
fixed issue with tethering bypass for some carriers
optimized some of my tweaks
fixed issue with musicfx crashing (if you want it back let me know)
other minor bug fixes
1.0 p8 (md5: 0de50bf3df63d8c53dc2eef6cd9d40f8)
fixed no sound on aux (and other sound issues)
fixed issue with some tweaks not getting applied
minor performance boost
1.0 p7 (md5: f3d4a9607ff97f4cda5dfef39b563755)
fixed issue with random locks/shutdowns introduced in p6 due to kernel changes
fixed issue with poor battery life due to kernel changes in p6
switched to hells kernel for the time being
1.0 p6 (md5: 7b7e67d5bf6146582641642bfc2ff4cd)
fixes settings issue
fixes GPU performance (so you can get your game on!)
removes lag that was introduced previously
added youtube resolution patch
other minor tweaks
1.0 p5 (md5: fb704679099fe4c6dece06f084140c64)
root is now fully baked in
wifi disconnect issue has been fixed
busybox updated to latest version
running Despair Kernel by default (thanks DespairFactor!)
1.0 p4 (md5: 4248f7f675d42951901ce9ee2c502803)
removed annoying verification message on boot
fixed issue with phone getting warmer than normal
minor tweaks for performance
1.0 p3 (md5: 2ed110acabe472e6cc126b8f351ff242)
added native multi-window option under developer options
attempt to allow root (should be baked in)
1.0 p2 (md5: 8f2778258fb80de96985492e4323d953)
fixed issue with sysinit
added unsecure boot by default
1.0 p1 (md5: de2b7d490ce138907c43e77683536084)
initial release
Info o romie:
Rooted
Init.d Support
Tether Provision Check Bypass
No Forced Encryption
No Verification Boot Message
Native Layers Support
Unsecure Boot
Busybox
Zipaligned
Buttery Smooth
Blazing Fast
Pobierz:
ROM: https://drive.google.com/file/d/0B1eHMO4u1XzKYnp0dXY0V3NJclk/view
Instrukcja:
  1. Pobierz:
    - nowy bootloader : http://4ndr01d.com/download.cfm?id=TC9EJjJKPyE0VCQ3VEddMjlcJT46QSghM0JWMzJAWk80TyVaP0ZZKypfWzBcTl86M0YlQk41NyIpNShEIAo=
    - nowe radio rom: http://4ndr01d.com/download.cfm?id=Ry9EJjJKPyE0VCQ3VEddMjlcJT46QSghM0JWMzJAWk80TyVaP0ZZKypbW0hXSU83MkBVNlsK
    - rom zamieszczony wyżej
  2. Umieść pliki na karcie pamięci/ urządzenia
  3. Wyłącz i uruchom tryb recovery
  4. Wykonaj pełne wipe
  5. Teraz instaluj
    - bootloader
    - nowe radio
    - na koniec rom
  6. Reboot
xda: http://forum.xda-developers.com/nexus-6/development/rom-jdx-1-0-t3121053
