Witam, przy próbie zainstalowania CWM-1.0-pepper występuje następujący problem:
Install recovery...
* daemon not running. starting it now on port 5037 * * daemon started successfully * ============================================= Step1 : Waiting for Device. ============================================= OK
============================================= Step2 : Sending some files. ============================================= 34 KB/s (738 bytes in 0.021s) 784 KB/s (63456 bytes in 0.079s) 3216 KB/s (2723840 bytes in 0.827s) 2182 KB/s (735308 bytes in 0.329s) 145 KB/s (596 bytes in 0.004s)
============================================= Step3 : Setting up files system partition. ============================================= su: permission denied * server not running *
Finished!
Aby kontynuować, naciśnij dowolny klawisz . . .
Bo znowu robię nie tak?? Bootloader mam odblokowany, czy muszęgo zablokować, jeżeli tak to w jaki sposób.
Maciek G
Install recovery...
OK
Finished!
11 odpowiedzi na to pytanie
