[Sony Xperia J][LB/UB]●►AlienRom™◄● | V6 RELEASED!!!| NOW WORKS ON LOCKED BL | 4.1.2
GeoHot
AlienRom Xperia J
  Cytat
Zamierzasz instalować niestandardowy ROM, nie ponoszę odpowiedzialności za uceglenie telefonu.
Cechy:
- Fully Zipaligned and Zipaligns every boot ( More Free RAM now )
- 100% Fully Supercharged ( Complete with proper init.d scripts and minfree tweaks )
- Deodexed
- init.d support pre-enabled
- Custom Bootanimation
- Auto Clean Function ( Cache wiped weekly and Dalvik Monthly )
- Pre-Rooted
- Flash Gordon
- Stock Based 11.2.A.0.31 ( V4 only, V3 and below is CM 10 based )
- LOCKED BOOTLOADER SUPPORT
- Xperia Z1 Media Apps and Wallpapers
- Edited Vold.fstab
- Viper4Android
- Bravia Engine 2 Libs working real time ( if you don't believe check out libs folder )
- Crossbreeder and Adrenaline Engine Scripts
- Adreno Booster Drivers
- Honami Themed Applications ( White )
- Stamina Mode ( Extended Standby Mode )
- NXT Framework ( Xperia SP )
- Android 4.4 Font
- Performance Control
- Busybox Pre-Installed
- Kitkat Launcher ( Alot better )
- Gradient Status Bar
- BoostMyXperia App
- Ultra Fast Build.prop tweaks
- 3G/2G Speed Increased
- Camera Quality Improved
- Sd Card as internal Memory ( so that you could install big games )
- Xperia Z Keyboard
- Performance Increased and Enhanced Deep Sleep Mode ( check the build.prop sleep.png )
- Xperia Z1 Carmode
- Xperia Z1 HD Wallpapers ( Experience Wallpapers )
- Small Apps Launcher
- Kernel Overclock to 1.5Ghz ( for V3 and Below since only V4 is stock based )
- Dual Recovery ( twrp=yellow : cwm=pink) ( for V3 and Below since only V4 is stock based )
- Pure Performances Gold Edition
post-1-0-17194900-1426529071_thumb.jpgpost-1-0-85561500-1426529069_thumb.jpgpost-1-0-29107900-1426529067_thumb.jpgpost-1-0-71513700-1426529063_thumb.jpgpost-1-0-16158900-1426529062_thumb.jpgpost-1-0-79700100-1426529060_thumb.jpg
Instalacja:
- Zrootuj telefon i zainstaluj recovery
- Skopiuj ROM na kartę
- Włącz telefon w CWM
- Wipe data/factory reset, a potem Wipe Cache Partition
- Przejdź do advanced i Wipe Dalvik Cache
- Format /system (TYLKO SYSTEM)(V4 i V5)
- Zainstaluj/sflashuj ROM i zainstaluj/sflashuj Rootfix.zip
- Przejdź do advanced i wybierz Fix Permissions
- Sflashuj kernel .31 umieszczony niżej
Pobierz:
AlienROM v5
https://docs.google.com/file/d/0B1feXwC_Auq4SHd4c1R1bGpZQzg/edit?pli=1
RootFix.zip
SuperSU Download
JB Kernel
ST26_Stock_Kernel_By_2010Matej_3.4.0_31_11.2.0.a.31 - 3.4.0
UPTADE V6!!
V6
- Stock Based ( might release a cm one )
- 5x4 Honami Launcher
- AC!D Audio Engine V8
- Lots of other battery improvements and some build.prop tweaks addition and removal
- Topdroid's Project Butter Script
- Minor Bug Fixes
- Fixed Performance Control FC
- Xperia Z2 Wallpapers
- New Movies App
Download Alien RomV6 zip
Źródło: [ROM][J][LB/UB]●►AlienRom◄● | V5 RELEASED!!!| NOW WORKS ON LOCKED BL | 4.1.2 - xda-developers
