Pawliniak Opublikowano 5 Listopada 2014 Zgłoś Udostępnij Opublikowano 5 Listopada 2014 CyanogenMod 10 Android 4.1.2 Jak wygląda? Pobieranie:Download Link: http://quarx2k.ruEpsylon3 Builds: http://defy.wdscript.fr/Mirrors: http://defy.bytekiste.de/http://d-h.st/users/QuarxGapps: http://goo.im/gapps/Minimal gaaps(Gmail,Market,Gtalk,Synchronisation) http://quarx2k.ru/gapps-jb-20120726-minimal.zip Gapps + Working Google Now - http://forum.xda-developers.com/show...php?p=30988910 Opis zmian: Pokaż ukrytą zawartość 12.07: Boot up14.07: Phone, Mobile Data, USB, Mass storage, Sensors, Camera(Photo), GPS/AGPS.18.07: Audio (thanks to maniac103), Video rec/play, Panorama, FM-Radio.19.07: Install app to sdcard, mp3 codec, video codec fixes, rework fm-radio, cyan update.22.07: Usb fixes, USB Tethering, Data Usage, Preferred Network (umts/cdma) selection, CrystalTalk23.07: Fix audio lock-ups (thanks to nadlabak), a2dp, fix volume change, OS FMRadio and fm volume change in background by maniac103, leds26.07: Themes, button backlight, fix lag bootanimation, imei/mac... cyanogen updates.28.07: re-fix button backlight, holo fm-radio, Option for enable/disable On-Screen Button(36dp)04.08: Fix volume rocker music controls, Realtime switch of OnScreenButtons and size of it, Phone/SMS apps now in memory all the time, Enable CPU TLS Register, Auto-Backlight Settings, Boosted governor by default... maybe forgot some more..08.08: Improved stablity of camera (bayer have problem with sound), DroidSSHD, Trebuchet, common stablity fixes.10.08: update Moto RIL to v4, fm-radio to lockscreen, hwui blacklist on mb525, fix realtime OnScreenButtons, Fix MotoPortal, Disable get local ipv6 adress.12.08: Auto-backup battd, Port phone features from cm9, Add national data roaming and make it optional (from AOKP).22.08: Fix ability change brightness of buttons(Defyparts), compass fix, Apollo intent fix (which fixes last.fm etc), dalvik heap 128mb -> 48mb, wifi changes25.08: Disable lock in memory Phone and sms apps(by users requests), fix OnScreenButtons, ipv6 tweaks.28.08: Fix 00:00:00:00:00:00 SSID in apps, fix audio routing in dock modes03.09: Fix Audio in video rec(not ideal) and decrease fps in preview camera (not in video), 2Channels for audio, DSP-Manager in software which support JB (ex, apollo) it's not a bug, support multiboot, wifi-tethering (thanks ot devs of ml2, maybe have bugs, not tested)04.09: Fix compass, update sgx libs to JB, fix wallpapers, improve video perfomance, new touch driver (for test, only 2 fingers for now, more will be enabled in next build).12.09: Fixed touch driver (allow touches upto 10), Fix for data connection, thanks to SlugZero, also some more fixes for stability ril, disable fps limit in preview.24.09: Video rec fixes, add 720p rec (not by default, unstable),cyanogen updates.2ndboot builds: one build for mb525&52610.10 Android 4.1.2, CRT-Animation , custom kernel, experimental. Included patch for flashlght(not tested, but shouldn't burn it)11.10 Fix red camera, updated 2ndboot.ko, fix pds mount and permissions.18.10 Kernel update:fix wifi tether(reboot), reduce battery drain, fix charge only mode, cleanup unused drivers, fix button lights, fix slow boot and lags after boot.02.11 Add power hal, interactive governor+bootpulse(should be default in bootemnu for correct work power hal),kernel fixes from upstream, cleanup/disable unused drivers, fix SGX clocks, add bp_ptc service(only service), fix battery drain, add fuse rw-ntfs/extfat fs support(not tested, but should work), fix backlight settings, fix small problem with fm-radio on notfication drawer, add cm file manager(can work incorrect), restore live wallpapers, cm sync....17.11 Update kernel to 2.6.32-60, backport some optimisation from 4.2, fix mount options for ext4, cyanogen update, restore conversion to RGB->YV12 for video.18.11 Apply many optimisations: Android compiled with latest Linaro toolchain GCC-4.7, kernel compiled with Linaro toolchain GCC-4.5.4. Little wifi fixes.28.11 Disable linaro for android, fix adhoch, new battd, fix bt.04.12 Partial linaro, Fix upnp/dlna(thanks to nadlabak), fix reboot in bootmenu/recovery, cyan fixes.05.12 Fix root, fix adb, fix ROOT/ADB settings from dev menu , cyan fixes.22.12 Stability fixes, cyan updates.23.12 Fix shutdown, built-in call rec function(thanks to nadlabak).29.12 Revert to .9 kernel (for audio tests and stability), fix root permissions on CMFileManager, adb can be disabled now, bootmenu now has only one custom recovery option.30.12 Restore .60 kernel, some fixes in android which can cause ringing problems.07.01 Again fix root permissions on CMFileManager, fix battery when ADB disabledl, again some fixes which can cause ringing problems.17.02 rgnd service, increase performance of camera.07.03 Fix for deskclock (from YetAnotherForumUser). Based on clean 2.6.32 moto tree, should fix many random problems... or add more24.03 Completely new wifi/wifi-ap driver, switch to wpa_supplicant8, Wifi ap AP - 72mbps25.03 Some fixes in wifi, fixed MAC, WiFi direct implemented26.03 Improved stability of wifi.09.04 Suspend optimization.11.05 Updated USB-Gadget to native for 4.x, fix mtp/ptp/storage/tethering. Removed usb.apk/usbd.16.05 Very experimental build, contain a lot of updates from kernels 2.6.33 - 3.1. Increased performance, added swap. Memory management updated to 2.6.39(3.0) state. Some parts updated to 3.1. Blechd0se patches for interactive gov.22/23+ experimental.16.06 Updated wifi driver & wpa_supplicant, improvement in interactive governor by @Blechd0se. Updated kernel with some patches from upstream.09.07 Stability fixes. Updated bootmenu. This build not contain ZCache/Zram/Swap30.10 Fixed Video playback, latest kernel changes(same as 10.2), gpu 266mhz...Instrukcja:Wyłączamy telefonPrzechodzimy do recoveryWybieramy Wipe wykonujemy (Cashe, Dalvic Cashe, Format Data)Wracamy do głównego ekranuWybieramy Install następnie rom60 sekund i mamy nowy romWracamy do głównego ekranu wybieramy ponownie install i gapps10 sekund i mamy paczkę googleWracamy do głównego ekranu i wybieramy rebootŹródło: http://forum.xda-developers.com/showthread.php?t=1768702 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
