[Samsung Galaxy Ace] CyanogenMod 11 modded - [nightly-20140326]
[Galaxy Ace] CyanogenMod 11  modded - [nightly-20140326]
Nieco podrasowany CM 11 dla posiadaczy Galaxy Ace
  • CWM Recovery wer 6.0.4.X lub TWRP 2.7.0.X
  • Galaxy Ace S5830 - wyłącznie!!!!
Zmodyfikowano:
  • contains additional google libs, permissions and framework files.
  • Some apps removed like music.apk, CM Filemanager (needed the space on system and there are some better apps on market)
  • (2013-12-26) slimmed down some system apps
  • (2013-12-26) Removed Launcher3 and added Apex Launcher v2.2.0
  • (2013-12-26) added Total Commander File Manager v 2.03 final
  • (2013-12-26) added some tweaks
  • (2013-12-26) integrated MA6 Kernel
  • (2013-12-26) integrated Google PlayStore to v4.5.10
  • (2013-12-26) replaced Camera with a working one
  • (2013-12-29) integrated some more tweaks
  • (2013-12-29) activated statusbar transparency
  • (2013-12-29) integrated Lockscreen PIN-unlock Fix
  • (2014-01-11) switched Camera back to now working cam from androidarmv6
  • (2014-01-11) integrated AGPS-fix V5
  • (2014-01-11) made 2nd variant with facebook contacts sync ability
  • (2014-01-11) integrated patched services.jar (thx to ullasmanju)
  • (2014-01-11) added some missing permissions xml files (this fixes outgoing voip/sip calls)
  • (2014-01-11) temporary override of low memory device flag, to enable custom lockscreen widgets and transparent statusbar
  • (2014-01-23) no more override of low memory device flag needed
  • (2014-01-23) updateded Apex Launcher to v2.3.0 beta1
  • (2014-01-23) updated Total Commander File Manager to v2.04 final
  • (2014-01-23) updated the integrated MA6 Kernel
  • (2014-01-23) updated remount script
  • (2014-01-23) updated Email & Exchange
  • (2014-03-11) updated the integrated MA6 Kernel
  • (2014-03-11) updateded Apex Launcher to v2.3.0 final
  • (2014-03-26) updated the integrated MA6 Kernel (frandom)
  • (2014-03-26) updated PlayStore to v 4.6.17
post-7223-0-98004000-1397674452.pngpost-7223-0-10508300-1397674466.pngpost-7223-0-39058200-1397674479.png
  1. Pobierz ROM
  2. Wrzuć pliki na kartę pamięci
  3. Uruchom tryb recovery
  4. (Wykonaj kopię zapasową o ile instalujesz pierwszy raz CM)
  5. Wykonaj pełne wipe (cache, data, dalvik-cache)
  6. Zainstaluj ROM
  7. Reboot
CWM : CWM-6.0.4.7-cooper.zip
ROM:
Version with CM-Superuser http://www.androidfilehost.com/?fid=23329332407582588
Version with CM-Superuser and Facebook sync ability http://www.androidfilehost.com/?fid=23329332407582589
Extras Package http://www.androidfilehost.com/?fid=23329332407582569
Gapps: - brak
Inne dodatki:
For enabling BLN support: NSTools
For Configuring BLN: BLN-Control-Free or BLN-Control-Pro (ignore not supported warning, it will work when enabled with NSTools)
Apps to SD: Link2SD
File Explorer: Total Commander (already included in rom but maybe you wanna use plugins)
FM-Radio: Spirit FM (Spirit is a real, tuned, over-the-air FM radio app for Android. It does not require Internet access.)
CM10.1 Wallpaper: cm10.1-Wallpaper.zip
CM10.1 Live Wallpaper: cm10.1-live_wallpaper_apks.zip
Google NOW: (needs updated version, will upload soon)
ROM Wallpapers Pack: Wallpapers from AOKP,AOSP,PA,CM
Battery Full Notification: Battery Full Notification
Snapdragon™ BatteryGuru v1.5.1 (from Xiam Technologies Limited, a Qualcomm company)
For Bluetooth: Bluetooth A2DP Volume
xda: http://forum.xda-developers.com/showthread.php?t=2587481
  • 7 miesięcy temu...
Dziękuję za odpowiedz,mam jeszcze pytanko, czy ten rom, jest na pewno dla mojego modelu telefonu?Bo w opisie, jest to galaxy ace s5830 a ja mam ace GT-S5830,czy to ma jakieś znaczenie? Czy mógłbyś ewentualnie zaproponować jakiś inną wersję cyanogena dla mojego modelu telefonu?
dzięki za info, zainstalowałem CWM recovery ver.6.0.4.7. I po wejściu w recovery nie mam w ogóle opcji install from sdcard,tylko chose zip from/storage/sdcard0 i chose zip from last install folder.Ponadto wyświetla mi jakieś info typu; E: can't open cache/recovery lub E: can't mount cache/recovery i jest tego kilkanaście linijek.Tak jak by nie widział karty sd;(
  • 8 miesięcy temu...
