[Ideos X5 U8800] CyanogenMod 11 - Nieoficjalny
[ideos X5 U8800] CyanogenMod 11 - Nieoficjalny
Nieoficjalny rom dla posiadaczy Huawei.
Rom jest w fazie testowej, więc posiada jeszcze błędy.
Info o błędach:
  • USB OTG may not work all the time.
    Fix: Toggle the mode on/off
  • Atmel TS may not recognize finger release at all times.
  • Portrait video recording is not aligned properly on resolutions below 720p.
  • AVI cannot be played by native player.
  • SIM lock cannot be turned on/off.
  • Various Wi-Fi issues (no hotspot, some networks cannot be connected).
  • TV out is not implemented.
Lista zmian:
24.02.2014
AAC playback fixed.
Fixed LEDs pulsing in wrong order.
Notification->Attention->Battery (LED priority list).
Reverted to older Synaptics driver (should fix lockups).
Rebased kernel to kk_2.7_rb1.27.
Fixed some volume/audio problems (need to be confirmed, speaker mode in call is still bugged).
Fixed microphone not muting while in call.
Fixed problems with FM radio volume (going loud when switching).
Fixed sound recorder.
Adjusted proximity sensor thresholds.
Fixed battery capacity (using Huawei method for now).
Enabled zRAM (thanks to @forumber2).
09.02.2014
Rebased kernel on kk_2.7_rb1.22 (minor fixes, better graphics performance).
Fixed Synaptics TS freeze (finger not tracked) (not confirmed).
Fixed display freezing on some targets.
Added pulsing notification leds with customizable speed (hardware blinking).
Fixed RIL without SIM.
Fixed sometimes phone going very laggy (caused by RIL).
Added FM radio support.
Decreased speaker db range (should improve quality).
Added v2 of DeviceSettings (now called IDEOS X5 Settings)
Added support for customizable BT power.
Added support for customizable charging current.
Adjusted proximity sensor (50mA current lets more IR light through).
Removed bloat from camera HAL (WiP).
Rebased kernel on latest branch for KK (improves graphics & minor fixes).
Added more codecs to support more audio/video formats.
Fixed some VIDC memory leaks (causing video recording/playback problems).
Removed unused adreno library & replaced with a new one.
19.01.2014 (These changes have been made upon the latest cm-10.1 version)
Updated codebase to cm-11.0.
Fixed camera flash.
Fixed video recording.
Fixed video HW playback.
Applied some fixes to audio HAL.
Fixed a problem where the charger was shown connected even though it wasn't.
Applied smaller fixes to display driver.
Released some unused memory.
Using MDP retire fence (may fix some display problems).
Removed some unused kernel drivers.
Updated android kernel counterpart drivers (binder, lowmemorykiller)
Updated freezer driver.
Enabled SELinux.
Added CMHW vibrator scaling (in Settings->more).
Stripped vibrator tuning from DeviceSettings.
Added modifiable button brightness.
Added modifiable notification leds.
Greatly reduced init.rc scripts.
Enabled KSM.
Added QCOM optimizations for faster CPU operations.
Added support to multimount UMS (internal & external).
Added support for /data encryption.
Added torch with two brightness setting.
Fixed some camera problems.
Added Finnish translations to DeviceSettings (zazza97)
Enabled QCOM Audio/Video enhancements.
Enabled low_ram flag.
Updated synaptics driver.
Smaller fixes for APS-12D driver.
Disabled highmem in kernel (should reduce the footprint a lil).
Fixed Wi-Fi not starting problems.
Reduced the time where display does not enter/exit sleep properly.
Updated CPU power management driver.
Updated FUSE driver (for SD cards).
Removed some unused memory allocations.
Build RIL daemon and libril from source.
Removed some bloat in camera HAL.
  • ROOT
  • Najnowsze CWM lub TWRP Recovery
gapps:
http://wiki.cyanogenmod.org/w/Google_Apps
  1. Pobieramy ROM i Gapps
  2. Wrzucamy pliki na kartę pamieci
  3. Wyłączamy telefon
  4. Uruchomiamy CWM /TWRP Recovery
  5. Wykonujemy pełne wipe
  6. Instalujemy ROM
  7. Instalujemy Gapps
  8. Reboot
xda: http://forum.xda-developers.com/showthread.php?t=2616956
