[Galaxy S Plus] CyanogenMod 11.0 by ADC-Team - Release 9 Android 4.4.4
Pawliniak
CyanogenMod 11.0 by ADC-Team 4.4.2
Nie działa:
SD swap
Download:
TWRP 2.8.1.0 recovery [21/12/2014]: [DevHost Mirror] [MediaFire Mirror]
MD5: b703980bcc607e829e9e4a50193b6f13
Note: This recovery includes new partition assignments
ADC Team Gapps [04/07/2014]: [DevHost Mirror] [MediaFire Mirror]
MD5: c488b0be3e93105ae0423583039d6b1c
CM 11.0 Release 15 [22/12/2014]: [DevHost Mirror] [MediaFire Mirror]
MD5: af3d01264deb558d2587137b466dc6f3
Info:
- KitKat 4.4.4 (KTU84Q)
- Synched with CM sources
device/samsung/ariesve
- Revert "Enable proximity wake" (credits to Christopher83)
- Revert "Put back dalvik.vm.dexopt-data-only=1" (credits to arco68)
- Revert "Set resampler quality" (credits to arco68)
- Various updates and cleanups (credits to arco68)
- ariesve: Enable IPv6 tethering (credits to sirmordred)
- ariesve: Set default locale to en_GB (credits to arco68)
- lpm: Updated offmode charging binaries (credits to sirmordred)
- prop: Set max background service to 4 (credits to arco68)
- overlay: Don't show mobile plan preference (credits to arco68)
- ramdisk: Change the assignment of partitions and use an emulated sdcard (credits to Christopher83)
- prop: Use /cache partition to store dex files of system apps (credits to Christopher83)
- prop: Set MTP as default USB interface (credits to Christopher83)
- config: Add USB audio support (credits to tobigun)
vendor/samsung/ariesve
- Add router advertisement daemon for IPv6 tethering (credits to sirmordred)
Zrzut ekranu:
Działanie:
Instrukcja instalacji:
http://forum.cyanogenmod.pl/index.php/topic/525-jak-wgra%C4%87zainstalowa%C4%87-rom-samsung-galaxy-s-plus-i9001/
http://forum.cyanogenmod.pl/index.php/topic/12-rootunroot-szybko-i-przyjemnie/
TWRP_2.7.0.0_ariesve_20140404-signed.zip
źródło: http://forum.xda-developers.com/showthread.php?t=2579431
Edytowane przez Pawliniak
Jaka jest różnica między bricked / not bricked devices ? Sorki, ale dopiero raczkuje w tej dziedzinie :P
Wgrałem CWM v6.0.3.8 No Touch Version, o takie recovery mi chodziło, gdyz nie jestem zwolennikiem dotykowych wersji :) Dzięki wielkie.
Po instalacji CM'a, próbowałem zainstalować gapps'y ale wypluło ten błąd, jednakże po uruchomieniu automatycznie aktualizował apki więc myślę ze jest dobrze, już nie kombinowałem i zostawiłem jak jest :)
Sama nazwa mówi.
Jak telefon zostanie uceglony to wgrywasz wersję bricked
A jak telefon nie jest uceglony to wgrywasz wersję no bricked
Dodano nowszą wersję do pierwszego postu:
Lista zmian w wersji 4:
  • Synched with CM sources
  • ril: fix custom RIL for new API (credits to CastagnaIT)
  • BoardConfig: enabled legacy sensors fusion (credits to CastagnaIT)
  • recovery: pre-built kernel no longer needed (credits to krislibaeer)
  • recovery: support twrp recovery (credits to krislibaeer)
  • sepolicy: add more selinux for rmt storage fix shutdown issue with new recoveries (credits to krislibaeer)
    framework/base
  • Restored original autobrightness speed (credits to CastagnaIT)
  • Improved the minimum amount of time that must have elapsed for change the rotation (credits to CastagnaIT)
  • Frameworks: Lockscreen Blur (credits to CastagnaIT)
    framework/native
  • sensorservice: Add legacy sensors fusion. (credits to CastagnaIT)
  • native: add flag to disable legacy sensors fusion (credits to CastagnaIT)
    packages/apps/Settings
  • Lockscreen: See through (2/2) (credits to CastagnaIT)
  • Settings: add Advanced menu for device-specific settings app (credits to CastagnaIT)
  • Add lib for WVM extractor (credits to arco68)
Panowie mam problem
Zainstalowałem ten Rom jakieś 2 tygodnie temu - telefon fajnie działa , natomiast nie mogę uruchomić GPS-a (Nie wykrywa satelitów).
Zainstalowaną mam wersję Release 2 , po instalacji Romu nie mogłem zainstalować Gaps-ów (TWRP 2.6.3) - czy ich zainstalowanie pomoże rozwiązać problem?
Napiszcie  czy Wam GPS działa - ewentualnie jak sobie z tym poradzić.
