[LG Optimus L9] CMX CyanogenMod 10.2
Prezentuje wam modyfikację "podrasowanego" CyanogenMod 10.2
Oczywiście jest on na kodzie CM, ale z dodatkami.
Informacje od autora:
- My personally modded CM 10.2 ROM
- ramhack included in kernel, memory is now 850mb
- Holoshade Theme Chooser Theme set by default
- AROMA Installer, pick whatever you want preinatalled with the ROM
- Option to install with navbar enabled or disabled
- ViPER4Android integrated for a much better audio experience (Enable from installer, always up to date)
- Added my Codename LightningBolt tweaks
- Improved GPS (forgot to apply in last update)
- Replaced Trebuchet with latest Apex Launcher beta, included Apex Notifications 2.0 beta as well
- Custom UI sounds and handpicked system audio (most of which is bases on MGS4. Must re-add)
- My sysctl tweaks
- Better adblocking, safer browsing
- Option to enable navbar in the installer
- No emulated internal storage. Single external SD card configuration (read note in this post) you can thank AntonX for this good.gif
- Apps2SD support
- Support for Notification Lights, either native or with BLN (read note in this post)
- Analog amplifier gain control with Voodoo Sound support (read note in this post)
- Microphone preamplifier gain adjustments
- Performance kernel with OC/UV
- Advanced Settings to control kernel clocks
Kernel
- Kernel from AntonX's source
- Compiled with Linaro 4.7
- Extended frequency table with 200MHz, 1200MHz, 1350MHz (overclocking doesn't work on some phones)
- Slightly undervolted
- Userspace voltage control. Use SetCPUVoltageControl, or similar. Warning: Save a recovery script with either of these programs before playing with voltages!
- GPU is extended with 384MHz, IVA with 430 MHz
- Selectable screen-off maximum frequency
- Included SmartassV2 governor, SIO scheduler.
- Few performance tweaks.
- ramhack included, free memory is now 850mb
Pobierz:
ROM: CMX CM 10.2
Gapps: http://d-h.st/sEX
FIX dot Kamery i nagrywania :
http://d-h.st/gDu
Instalacja:
  1. Pobierz ROM i Gapps
  2. Wrzuć na kartę pamięci
  3. Przejdź w tryb Recovery
  4. Wipe ( jeżeli wgrywasz z czystego firmware)
  5. Zainstaluj ROM i Gapps
  6. Reboot
xda: http://forum.xda-developers.com/showthread.php?t=2641489
  • 1 rok później...
  • 5 miesięcy temu...
