[One Plus 5] Boeffla Kernel [OOS 4.X.X]
King_Stone_69
Świetny niemiecki kernel znany z efektownego działania na Samsungu Galaxy S3
  • TWRP
  • odblokowany bootloader
  • Support of anykernel concept (only latest kernels) - flash stock kernel before flashing Boeffla
  • Full integration with Boeffla-Config V2 (you need at least version 2.4.38 or higher !!!) configuration app (get it from http://www.boeffla.de) to configure all kernel settings
  • Dash charging fully supported
  • The two CPU clusters (big and little cpu) can be configured completely separate in terms of min/max frequencies, governors and CPU core profiles
  • Additional governors: none yet, but planned
  • Additional schedulers: fiops, bfq, sio, sioplus, fifo, vr, tripndroid and zen
  • Underclocking CPU and GPU supported
  • No CPU overclocking and voltage interface, no GPU overclocking and voltage interface (not planned too)
  • GPU boost implemented (4 levels)
  • CPU core profiles to restrict number of CPU cores being used (the OP5 does not hotplug based on load)
  • USB charge rate bumped up to 900 mA
  • Notification LED control (effect + speed for blinking/fading, brightness for continuous notification like battery charging etc.)
  • Boeffla-Sound engine V1 (headphone volume control)
  • Dynamic FSync (activated if screen on, deactived if screen off), configurable
  • Input boost frequencies and duration configurable per CPU cluster, input boost switch
  • Show CPU frequency usage per CPU and frequency in Boeffla-Config
  • Show current CPU core frequencies in realtime (note: other apps than Boeffla-Config will likely display wrong information on offline cores as they are not up-to-date yet)
  • Show GPU frequency usage per frequency in Boeffla-Config
  • KCal V2 Color control
  • Swipe2wake gestures
  • Control haptic feedback of gestures (except fingerprint)
  • Haptic feedback intensity control (from 0 to 25, with 25 being 100%)
  • Swipe2sleep gestures
  • SD card read ahead buffer configurable (default increased to 1024 kB)
  • Ext4 File system tweaks (default to on, can be disabled)
  • Kernel logger (dmesg) configurable
  • CIFS support (module, do not mount inside /data, if you rooted with Chainfire SuperSu, make sure you uncheck the namespace separation in SuperSu app)
  • NFS read-only support (module)
  • NTFS support (module)
  • XBox support (module)
  • OTG-Ethernet support (module)
  • TCP Congestion changed to Westwood
  • Many additional TCP congestion algorithms available
  • Entropy values configurable
  • Hardware touch keys locked as long as screen is in use (touched) for better usability (default, but configurable)
  • Swap supported
  • Various kernel tweaks
  • Doze mode configurable in Boeffla-Config
  • Full selinux strict support (switchable to permissive on demand)
  • Show speedbin information (PVS level) in Boeffla-Config app
  • init.d support (in /system/etc/init.d - set correct permissions!)
  • Automatic EFS backup
  • Fully supports OOS device encryption, but does not force it
  • Integrated full busybox 1.26.2 (own compilation)
  • Compatible with systemless root
  • Safetynet: verifiedbootstate + additional flags removed
  • Kernel initialisation log file (with history of 3 log files)
  • Emergency reset script automatically placed into /boeffla-kernel-data folder of your internal memory
  • Google gcc 4.9 toolchain (64 bit) used for best stability
  • Always based on latest OOS kernel sources
  1. Wrzuć kernel na urządzenie.
  2. Przejdź do TWRP.
  3. Zainstaluj kernel.
