[LG G2 mini]Temasek's UNOFFICIAL Cyanogenmod 13
Nieoficjalna modyfikacja CM 13.
  • Odblokowany bootloader
  • ROOT
  • CWM/ TWRP
Informacje:
Spoiler
All CM features (themes, adjust buttons, skip track with volume etc.)
Sound
Viper4Android
adjustable volume steps (alarm, DTMF, music, notifications, ringer... helpful if you want e.g. many steps for music but less for ringer)
Enable/disable camera shutter
enable/disable screenshot sound
Statusbar
Double-tap-to-sleep statusbar to turn display off
Clock: (alignment, color, date, font, size, seconds)
Battery symbols and battery bar
Temperature
Brightness control (slide over status bar to adjust)
Network traffic (incoming and/or outgoing)
Carrier label
Notification count
Disable Headset icon
Disable SuperUser icon
Configure all status bar icons which should be shown/hidden (Cast, Hotspot, Bluetooth, Do not Disturb, Alarm, Wifi etc...)
Notification drawer
Task manager
Custom header image (see screenshots for example)
Quick and smart pulldown
Show/hide brightness slider and/or brightness icon
Force expanded notifications for apps which supports it
hide immersive mode messages
additional tiles
QS panel background transparency
Lockscreen
Weather information
additional shortcuts
Change corner shortcuts
Double tap anywhere to put device to sleep
Different fonts for Lock Clock
Enable torch on power button longpress while having screen off
Blur lockscreen
Recents
AOSP recents (with clear all, memory bar, search bar...)
Omniswitch aslo as main recents possible when home button long pressed
SlimRecents (Recents as sidebar, with many customization like only showing active apps etc....)
ParanoidAndroid PIE control
On-the-go mode: camera as semi transparant overlay over your display
Adjustable Power menu
App circle bar
Gestures anywhere
Configurable Toasts and other animations
Heads-Up White- and Blacklist
Instrukcja:
Pobierz ROM i Gapps
Wrzuć pliki na kartę pamięci /pamięć telefonu
Wyłącz telefon
Uruchom tryb recovery
Wykonaj pełne WIPE
Zainstaluj ROM, potem Gapps
Reboot
Pobierz:
ROM: https://basketbuild.com/devs/MobiusM/Temasek
Gapps:http://opengapps.org/
xda: http://forum.xda-developers.com/g2-mini/development/rom-temasek-s-unofficial-cyanogenmod-13-t3364708
