NeoCM Opublikowano 23 Maja 2016 Zgłoś Udostępnij Opublikowano 23 Maja 2016 [Galaxy S3 LTE] [AOSP][OFFICIAL] CyanideL v4.0 - MM6.0.1 Rom oparty na AOSP z dodatkami od innych oczywiście. Wymagania: ROOT CWM/ TWRP Lista zmian: Spoiler *AdBlocker *App Circle Bar *Breathing Notifications *Custom LCD Density *Custom Lockscreen Circle Shortcuts (up to ten) *Custom Lockscreen Slider Shortcuts *Expanded Desktop *Heads Up Customizations and Timeout *Gesture Anywhere *Gesture Lockscreen *KeyPad Shuffler on Lockscreen Security *Privacy Guard *Lockscreen Notifcation PER APP Controls for Normal OR Secure Lockscreen *Priority Notifications *Battery Saver Custom Color *MultiUser Support *WhisperPush Support *Long Press Back to Kill with Timeout Options *SuperSU Included and Built Into Settings to Replace Standard SuperUser *Advanced Reboot and Unknown Sources Install by Default *Heads Up Notifications *Notification Light and Color Control (Device Dependant) *Cyanide L Pitch Black Theme ( was hard coded but we have reverted to stock white and made it a theme engine theme, download above) *Custom Toast, System, ListView Animations and Scrolling Modifiers *Custom Power Menu Options *Custom Quick Settings Tiles WITH Custom Colors, currently we have 36 Tiles *Quick Settings Custom Options including Vibrate, Force Expanded Notifications and many others *Recents Apps Clear All Locations, Search Bar Enable/Disable and Option to use OmniSwitch if you prefer *Shift Tools (Kernel/Performance Control App Built by ME(Rogersb11) *System App Remover *Wakelock Blocker *Hardware Keys Disable Option *Status Bar Battery Mods Including Styles (Battery Bar Included), Custom Colors for Icon and Text and Charging Animation Control *Status Bar Clock and Date Options Including Custom Color, Font Style, Clock Location(Left, Right and Center) *Custom WiFi and Network Icons Colors *Network Speed Indicator with On/Off switch, Custom Colors and AutoHide Option *Status Bar Header Icon and Text Custom Colors *Smart Control (Direct Call in MMS or Dialer like TouchWiz) *FULL Ambient Display Implementation as Active Display from KK (Thanks Squadzone and OmniRom) *Nova Launcher *Cyanide Central with Downloads, Source Links, Google Plus and Source Links as well. Each device has it's own tab *Status Bar Weather Control with Custom Color and Location Support *Custom Statusbar Icon Colors *Custom Notification Headers and Icons Colors *Status Bar Ticker *Status Bar Notification Count *Status Bar Logo *Status Bar Custom Greeting *Full Weather Control Panel *Lock Screen Weather with Custom Icons and Text Colors *Screen Recorder *Navbar for ALL devices with custom actions, shortcuts and numerous custom layouts as well *CyanogenMod Theme Engine *AudioFX *SlimPIE (WORKING, I use it everyday) *Custom Carrier Label with custom color in Statusbar *Long Click Support in Statusbar Header *Cyanide Shortcuts and Actions Instrukcja: Pobierz: ROM:https://www.androidfilehost.com/?fid=24533103863138053 Gapps:http://opengapps.org/ xda: http://forum.xda-developers.com/galaxy-s3/development-i9305/rom-cyanide-l-rc-15-0-5-1-1-r5-i9305-7-t3148913 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
