NeoCM Opublikowano 20 Maja 2016 Zgłoś Udostępnij Opublikowano 20 Maja 2016 [Galaxy S7 EDGE] [STABLE][TW][6.0.1][APDN][SM-G935F/FD] SuperMan-Rom V1.5.1 Custom rom oparty na zmodyfikowanym stocku. Wymagania: ROOT CWM/ TWRP G935FXXU1APDN bootloader G935FXXU1APDN modem lista zmian: Spoiler - G935FXXU1APDN Base - Prerooted with V2.73 or v2.68 SuperSU (choose in aroma!) - Latest Busybox installed (1.24.2) - Aroma installer! - Developer options enabled by default - Full edge support! - Xposed V84 is installed (choose in aroma) - Adblocker enabled - Zipaligned - choose IOS emojis in aroma - Init.d support in Kernel - Choose between 15 and more different CSC to match your country! - DM-Verity disabled - Force encrypt disabled - ADB fully working - Rounded UI (SystemUI tweaks if you choose in aroma) - Applock feature build in - Many csc tweaks! - No sms to mms auto convertion - Allow all apps in multiwindow - Removed Grey statusbar in powersaving mode - Updated all samung apps to recent version - Bringing buttons "only once / always" to select when the task application "Open With." - USB Plug/Unplug disable wake up - Remove high volume warning for headphones - Emergency mode" in "Settings/Lock screen and security - Private mode fixed - Enable Display Scaling in Settings - Enable TouchKey light duration in settings - Enable OutdoorMode - Fully Deodexed - Removed low battery warning - Knox stuff is removed - Stock APDN Kernel included - Latest TouchWiz Sources! - Debloated, but fully functional (all removed apps can be install with playstore) - Selinux Enforcing - Sound Mod V16 with lot improvements! (choose in aroma) - Updated all samsung apps - May Security Patches - Many other features, please read changelog to see what changed over the time Instrukcja: Upewnij się, że masz w/w bootloader i modem, jak nie to pobierz z tąd i wgraj https://www.androidfilehost.com/?w=files&flid=54002 Pobierz ROM Wrzuć pliki na kartę pamięci /pamięć telefonu Wyłącz telefon Uruchom tryb recovery Wykonaj pełne WIPE Zainstaluj ROM, Reboot Pobierz: ROM https://www.androidfilehost.com/?fid=24533103863141786 xda: http://forum.xda-developers.com/s7-edge/development/rom-s7-edge-rom-v1-1-t3356699 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
