NeoCM Opublikowano 29 Lutego 2016 Zgłoś Udostępnij Opublikowano 29 Lutego 2016 [Huawei Mate 8] Rayglobe Italian Knife Ver 1.7 * TWRP - Root - Debrand Jest to program, który ma Ci ułatwić życie.. w skrócie pozwoli na instalację: TWRP ROOT-a Debrand Odblokuje bootloader Wymagania: Sterowniki USB wgrane Włączone opcje programistyczne Program Rayglobe https://www.androidfilehost.com/?fid=24415232478677211 Instrukcja: Pobierz program i go wypakuj. Uruchom program: Następnie wybieramy opcje które nas interesują: * odblokowanie bootloadera tyczy się oficjalnej metody, więc trzeba pozyskać kod od huawei Opis funkcji [ENG] Pokaż ukrytą zawartość ************************************************** *********************************************** --------- User Manual HUAWEI MATE 8 Italian knife by Raimondo Martire (aka acer73) V1. 2 ---------- * * ================================================== ======================================== **************The following points can be activated only with ADB and FASTBOOT active ** *****0: FIRST START *****1: BOOTLOADER *****2: Recovery *****3: Root *****4: gapps *****5: debrand 6: UNBRICK 7: EXTRA 8: Download EMUI 9: Thread Huawei Mate 8 on HDBlog.it ** *****Q: Donate and Thanks? HELP (hdblog.it) X: CLOSE ================================================== ======================================== * Before you start remember stop/freeze the antivirus because it may interfere with the download * ================================================== ======================================== * MENU 0: First Start * In this menu, 'there are two preliminary operations are the driver installation for the proper functioning of the options adb and software download Hisuite. Remember not to jump the menu '"First start" because you will need to verify that you have properly enabled the option "USB debugging" in the menu 'developer * ================================================== ======================================== * MENU 1: Bootloader * In this menu 'you can use a fast tool for a fee ($4) to unlock the bootloader. Huawei also provides for an option to unlock via email. More information in this forum * NB. Unlocking the bootloader is necessary if you want to use all options of this tool * ================================================== ======================================== * MENU 2: Recovery * * 2-1 * The recovery TWRP need to install zip unsigned and root. * 2-2 * The stock is recovery available with Huawei rom * ================================================== ======================================== * MENU 3: Root * The root, from the English "root", is a process derived from Linux and applied on Android to get superuser rights and thus have unrestricted access to the system and to right to modify it at will by real developers. It is not nothing but to overcome a barrier and open the huge iron gates behind which hides the world of modding and custom ROMs. IMPORTANT: For the root must install the TWRP recovery and have the boot decrypt * ================================================== ======================================== * MENU 4: gapps * You can install Gapps for Huawei chinese rom. Please consider to decrypt boot before * ================================================== ======================================== * MENU 5: debrand * It really a pleasure to present this function for switch beetween chinese AL10 model to European L29 Model * ================================================== ======================================== * MENU 6: UNBRICK * It 'a menu' emergency and experimental enabled only when the smartphone is in brick state * ================================================== ======================================== * MENU 7: Extra * In this menu, 'there are more frequent reboots: recovery, bootloader and the possibility for the user to flash their own recovery or a boot image. The files must be placed in the directory USER * ================================================== ======================================== * MENU 8: Download EMUI * This menu 'will be active for download roms stock EMUI of the Chinese model. * ================================================== ======================================== * MENU 9: Thread Huawei Mate 8 on HDBlog.it * Italian forum when I've published first my work * ================================================== ======================================== * MENU D: Donate * This tool and 'released for purely private. Any commercial use without permission the author will be prosecuted according to law. If you want to keep this tool active currency the possibility to donate to the purchase of space Web and to give me comfort with a glass of good Italian wine * ================================================== ======================================== * Menu?: Help * To choose the menu 'for help and' exclusively in Italian * ================================================== ======================================== * MENU X: Close xda: http://forum.xda-developers.com/mate-8/development/rayglobe-italian-knife-t3295526 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
