NeoCM Opublikowano 19 Lutego 2016 Zgłoś Udostępnij Opublikowano 19 Lutego 2016 [Huawei P7][Unofficial TWRP Recovery 3.0.0-0] Nieoficjalne najnowsze recovery od TWRP Wymagania: Odblokowany bootloader System od 4.4.2-5.1.1 Fastboot Zainstalowane sterowniki USB Włączone debugowanie USB Info o opcjach w recovery: Spoiler Supports USB OTG, so you can use USB flash drive as external storage for backups, zip installations. Added feature to make backup/restore of internal storage. Added feature to make backup/restore of oeminfo partition. This partition contains info about vendor and current installed version. So in case if you want to rollback to 4.4.2, for example, or revert back your previous vendor version, you can just restore oeminfo from backup with 4.4.2 version or other vendor and flash appropriate firmware without flashing transition package, vendor and without getting "cust fail" error. Combined with stock EMUI 3.1 recovery. In case of power-on by holding power + vol+ or rebooting into recovery by command or any 3rd party application: will boot in TWRP. In case of local update, OTA-update, factory reset from menu or "force update" (3buttons method): will boot into EMUI recovery. Thus you don't have to flash stock recovery before OTA-update, flashing official firmware or doing factory rest. Off-mode charger updated from EMUI 3.1 (for 4.4.2) custom.bin and cust symlinks are saved/restored (if they were exist) in case of Wipe/Format Data. So there is not gonna be "cust" issues after factory reset in TWRP. Excluded SuperSU from build. Enabled encrypted data support. Screen lock by power button replaced with screen off. Instrukcja: Pobieramy plik img Umieszczamy go w folderze z fastbootem Uruchamiamy okno Podpinamy telefon pod USB WPISUJEMY:fastboot flash recovery TWRP_P7-3.0.0-0.img fastboot reboot To na tyle Aktualizacja z innej wersji recovery: Pobierz plik ZIP Wrzuć na kartę pamięci Uruchom tryb recovery Wgraj plik Reboot Pobierz: img: http://catshare.net/F2mU2kM1xyRwHjtx zip: http://catshare.net/NXSvuISG8a9ugjAd xda: http://forum.xda-developers.com/ascend-p7/orig-development/recovery-t3314665 1 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
