[Nexus 6P] BeanStalk 6.02 [Android M]
BeanStalk6_BeanStalk6.thumb.PNG.2738ed81
  • Odblokowany bootlader
  • ROOT
  • TWRP recovery 2.8.X.X
Cytuj
  • CyanogenMod 13 based
  • Quicker system animations
  • Trimmed down fat and excess bloat
  • Option to enable all widgets
  • Numerous extra lockscreen options
  • LCD Density
  • Custom original BeanStalk Wallpapers by skyliner33v
  • Custom BeanStalk bootanimation by skyliner33v
  • 3-minit battery support
  • Clock and date options
  • Contextual Header - Original and Polygraphic
  • Battery styles - Includes specific colors and styles. Also includes battery bar
  • Do not disturb option
  • Show notification count
  • Recent screen options
  • Customizable navigation bar
  • Use Omniswitch as default recents
  • Built-in screen record
  • Toast animations
  • App Circle bar
  • Gesture Anywhere
  • Disable FC warnings
  • Disable Immersive message
  • Force expanded Notifications
  • Configure scrolling cache
  • Build.prop MOD options to enable/disable tweaks as preferred
  • Less frequent Notification sounds options
  • CRT screen off/on options to specify how the animation shows
  • Enable/disable wake up on charge option
  • Superuser fully embedded into the build and accessed from settings menu
  • CM Performance options and features
  • Hide superuser icon
  • Developer options and advanced reboot enabled by default
  • Numerous cherry-picks and improvements throughout the build.. baked into the
    awesomeness of existing CM layout.
  • Numerous other options hidding throughout the build. For a full list of changes and features, please
    be sure to checkout change log below.
Instrukcja:
  1. Pobierz ROM i Gapps
  2. Wrzuć pliki na kartę pamięci
  3. Wyłącz urzadzenie i uruchom je w trybie recovery
  4. Wykonaj obowiązkowo pełne wipe
  5. Zainstaluj ROM, potem Gapps
  6. Reboot
PS. być może będziesz potrzebował zmodyfikowany blik boot.img zawarty w tej paczce: http://www.romwarehouse.com/scott.hart.bti/beanstalk/vendor_angler/
Pobierz:
ROM: http://www.romwarehouse.com/scott.hart.bti/beanstalk/angler/
Gapps: http://opengapps.org/
xda: http://forum.xda-developers.com/nexus-6p/development/rom-beanstalk-6-01-12-12-2015-t3269156
