NeoCM Opublikowano 16 Grudnia 2015 Zgłoś Udostępnij Opublikowano 16 Grudnia 2015 [Galaxy S3 LTE] [UNOFFICIAL] LiquidSmooth v4.1 Modyfikacja oparta głównie na AOSP z dodatkami od CM, Slim, Carbon. Bardzo schludnie zrobiona. Wyróżnia się na tle innych dostępnych na rynku. Wymagania: ROOT CWM/ Twrp Recovery FEATURES LiquidSmooth 3.2 New Bootanimation NavBar IME Cursor: Option to use Home / End instead of Up / Down on longpress Slim’s System app remover Add summary’s to advanced settings Add Liquid Weather Quiet Hours Extra Daily Times Add Second to Clock Disable Immersive Messages Pattern Size Upgrade Slide Left to Right, Right to Left Toast Animation LiquidSmooth Download Center Partition information menu Add Weather Status Bar Header ProximityWake : Add support for checking proximity when waking device OTG support. Exclude Heads Up on Lockscreen Notifications Open Heads Up on floating mode Show Heads Up at the bottom ViPER4Android replaced dsp manager Brightness slider to notification drawer MIUI carrier text Font Size Finally works PA Pie PA Pie Color Customizations Add Xposed Backup Script Add 6 bar signal DPI goes low to 160 Soft reboot options Control the size of the over scroll glow when scrolling NFC Polling – gives you the ability to use NFC from the lock screen LiquidSmooth 3.1 Linaro 4.7 Sabermod Toolchain O3 Strict-Aliasing & ISO C++11 Mode ARM Optimized String Handling Routines Linaro and Code Aurora Optimaztions Complete reshuffle of settings so it is more organized Credit: deadman96385 PA Theme Engine Credit: PA and Liquid0624 Wifi AP Priorities Credit: jruesga CM Profiles Credit: CM and Der-Schubi Searchable settings Credit: CM Build Prop mods (Use at your own risk) Credit: codenamedroid Ad Blocker Credit: Dirty Unicorns Startup Manager Credit: Kejar31 Quiet Hours rewrite Credit: Slim Identicons Credit: 0xD34D Lots of translations added Credit: All of the translators who worked on it New OTA System Credit: Team-Gummy and DrDevs Extra information about your device in about phone Credit: Dirty Unicorns Changelog available Credit: Steve Spencer Hover Credit: PA and Der-Schubi Heads up Credit: Slim Driving Mode Credit: AICP More peek options Credit: timpohladthomas, AICP, cristianomatos Reset battery stats option Credit: jruesga Flip Tile animation Credit: Der-Schubi Powermenu user switcher Credit: Der-Schubi Protected apps Credit: CM Expanded Desktop options Credit: CM LockScreen notification patches Credit: AOSPAL Shake Events Credit: Slim liquidSmooth 3.0 Features below are from SlimROM which are included in LiquidSmooth SlimPIE Quiet Hours Slim Recents Lock screen Style Notification Reminder Hardware key rebinding Custom Carrier label Smart Pulldown ADB over network Glowpad Torch Advanced Reboot Listview Animations Liquid Dungeon National Roaming Custom Tiles flip to Mute/Reject Call Incoming call in background Hide USB debugging notification Stylus Support Stylus Gestures Notification Drawer Style Lock screen pin shuffler Quick Unlock Status bar Brightness control Volume rocker wake Safe headset volume Privacy Guard Status bar clock style Status bar date style More... HALO Credit: PA/cristinamatos/xjcook/beerbong New CM Theme Chooser/Engine OmniRom App Circle Sidebar Credit: SquadZone Allow Disabling of FC messages Credit: jmztaylor PEEK Credit: PA Allow notification vibration during calls Credit: maniac103 Gesture Unlock Credit: 0xD34D Lock screen Notifications Credit: AOSPAL Development Shortcut Credit: sarbyn Switch Recent panel styles Credit: cristianomatos Battery Bar Credit: cphelps76 Status bar notification count and signal style Credit: burnsra & rmcc (cm) Status bar clock font style Credit: daxxmax Network speed indicator Credit: htchoi1995 Time-context headers to the notification header Credit: Xplodwild Ram Bar Credit: cristianomatos Custom Clear recents button Credit: cristianomatos Camera Button Support Credit: CM On the Go mode Credit: Evisceration Custom Lock screen wallpaper and blur Credit: david96 Audio Theme support Credit: Xplodwild Battery around unlock ring Credit: Xplodwild Gesture Anywhere Credit: 0xD34D Active Display Credit: 0xD34D/AOSPAL Alternate default app picker Based on @kufikugel 4.3 idea Toast Animations Credit: XuiMod Custom Progress Bar Credit: GwonHyeok Custom Scrolling values Credit: Squadzone Wake Lock Blocker Credit: Squadzone Multi user support for phones Credit: AlmightMegadeth00 IME Animations Credit: Squadzone Custom System Animations Credit: Steve Spear Battery Saver Mode Credit: OmniRom/timpohladthomas Instrukcja: Pobierz ROM i Gapps Wrzuć pliki na karte pamięci Uruchom telefon w trybie recovery Wykonaj pełne wipe systemu Zainstaluj ROM, potem Gapps Reboot Pobierz: ROM: https://www.androidfilehost.com/?fid=24052804347844832 Gapps: http://cyanmod.pl/gapps xda: http://forum.xda-developers.com/galaxy-s3/development-i9305/rom-liquidsmooth-v4-1-i9305-t3201828 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
