[ROM][Official][5.1.1][Nightly]CyanogenMod 12.1 Nightly for Huawei G620S,Honor 4/4X
Rocking
CyanogenMod is a free, community built, aftermarket firmware distribution of Android 5.1 (Lollipop), which is designed to increase performance and reliability over stock Android for your device.
* Your warranty is now void.
* We are not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at us for messing up your device, we will laugh at you.
CyanogenMod is based on the Android Open Source Project with extra contributions from many people within the Android community. It can be used without any need to have any Google application installed. You will need to provide your own Google Applications package (gapps). CyanogenMod does still include various hardware-specific code, which is also slowly being open-sourced anyway.
All the source code for CyanogenMod is available in the CyanogenMod Github repo. And if you would like to contribute to CyanogenMod, please visit our Gerrit Code Review. Your changelog is whatever was merged into gerrit.
Official CyanogenMod Wiki:https://wiki.cyanogenmod.org/w/Cherry_Info
Important information:
This thread is for official CyanogenMod 12.1 builds for Huawei Honor 4/4X (Qualcomm version). The following will not be supported here:
  • Custom kernels
  • Mods
  • Xposed
We don't support Xposed and any logcat which includes a Xposed module will be ignored. You're kindly invited to not report bugs if you:
  • Flashed a custom kernel
  • Installed or did mods from untrusted sources
  • Modified system files
Baseband requirement:
Your must install a compatible baseband before CyanogenMod can be installed, or you won't be able to disconnect a call.
Che1_L04
Che1_CL10
Che1_CL20
C8817D
G620S_UL00
G620S_L01
Known Issues: http://wiki.cyanogenmod.org/w/Known_...age_for_cherry
Bug report: https://jira.cyanogenmod.org
Features:
  • Kernel based on official kernel source for Honor 4C(MSM8939), ported to MSM8916, update necessary drivers to QCOM lolipop baseline, and update from v3.10.28 to v3.10.49.
  • Many vendor blobs kang from rendang
  • Init scripts from Qualcomm's latest baseline: LA.BR.1.2.4-02710-8x16.0
  • Use open sourced charger
  • Set minium screen backlight to 5
  • Fix CPU Hotplug
  • Enhance Wifi signal strength (credits: @surdu_petru)
  • Fix multi-color battery & notifiction LED
  • Fix FLAC playback for some third-party players
  • Enable MTP by default
  • Add call recording
  • Add support for F2FS
  • Add PCC calibration interface
  • Add vibrator intensity control
  • Add double-tap-to-wake
  • Add glove mode
  • Add HW-based crypto support
  • Update CPU gorvenor driver from Qualcomm
  • Update thermal driver from Qualcomm
  • Update kernel scheduler and related syscalls (sched) from Qualcomm
  • Update memory manager from Qualcomm
  • Update lowmemorykiller from Qualcomm
  • Update bluetooth blobs from rendang
  • Enable KSM
  • Merge a bunch of kernel updates from Qualcomm baseline (see kernel commit for details)
  • Set SELinux to enforcing mode
  • If your device have an official lolipop port, please install that before install this CM port.
Supported devices:
  • C8817D
  • C8817E
  • G621-TL00
  • G620S-UL00
  • G620S-L01
  • Che1-CL20
  • Che1-CL10
  • Che1-L04
Installation:
First time flashing CyanogenMod 12.1 on your device, or coming from another ROM?
  1. Download the zip(s)
  2. Install a compatible Recovery, e.g., my TWRP with F2FS support: http://forum.xda-developers.com/andr...overy-t3199386
  3. Perform a nandroid backup of your current ROM (Optional)
  4. Wipe data/factory reset
  5. Flash CyanogenMod
  6. Optional: Install the Google Apps addon package. OpenGAPPS recommended
  7. Reboot
Download:
http://get.cm/?device=cherry
Credits:
  • Code Aurora Forum
  • CyanogenMod Team
  • surdu_petru
  • EloYGomeZ
  • ivan19871002
  • syhost
  • zhaochengw
  • mandfx
  • cofface
XDA:DevDB Information
CyanogenMod, ROM for all devices (see above for details)
Contributors
dianlujitao, surdu_petru
Source Code: https://github.com/cyanogenmod
ROM OS Version: 5.1.x Lollipop
ROM Kernel: Linux 3.10.x
Version Information
Status: Nightly
Źródełko: http://forum.xda-developers.com/android/development/rom-cyanogenmod-12-1-nightlies-huawei-t3203635
