[Nexus 5] Resurrection Remix LP v5.5.3 (15/08/03)
CyanowyLenovo
post-69733-0-23212400-1439412574_thumb.j
Witam!
Przedstawiam wam kolejny ROM bazujący na kilku znanych ROM'achtak ich jak CyanogenMod, OmniROM, SlimROM.
Uwaga!
Pamiętaj że każda ingerencja w telefon można powodować jego uszkodzenie. Ja jak i całe forum nie ponosimy odpowiedzialności za usterki.
Instalacja:
1.Robimy Nandroid Backup
2. Robimy tzw. Full wipe zawieraon :
-Wipe Data
-Factory Reset
-Wipe Dalvik\ART
-Format System
-FormatPreload (ewentualnie)
3. ROM: Instal ZIP-> Choose From sdcard0-> wchodzimy do paczki z ROM'em i klikamy na yes
4. Gaaps: Instal ZIP-> Choose From sdcard0-> wchodzimy do paczki z Gapps'ami i klikamy na yes
Changelog:
Resurrection Remix Lollipop 5.1.1 - v5.5.3
- Anti-Piracy Support (Will be removed on next version)
- Display headset when plug
- Themes tile
- Add options - edit PIE control second layer
- Weather Temprature Status Bar Icon
- Statusbar weather color
- statusbar weather font size
- Fix left weather temp padding
- Fix for rare recents npe
- SlimDim: don't dim navbar on lockscreen
- SlimDim: Use semaphore to cancel ontouch callback
- GA = Fix size of close button drawables P2
- Add data connection toggle for MSIM
- Settings: Long Term Orbits (LTO)
- Don't include all resource densities
- Settings: Add TR Translations
- Automatic translation import
- Remove Duplicate Alarms
- Fix NPE with WeatherStatus on KeyguardStatusView
- SystemUI: Crash fix from bad camera values.
- CellularTile: Long-click triggers detail view instead
- CellularTile: Fix secondary button doesn't work and change single click behavior
- WifiTile: Fix wifi toggle state in detail view
- Only clear icon cache when theme/icon pack applied
- CaptivePortal : Ensure uri is not null
- SystemUI: Add support for external bitmap icons.
- systemui: Support remote expanded style.
- systemui: Fix various issues with transparent bars
- camera: Unbreak the extended face detection code
- ActivityManagerService: Don't export 'system' process in running app list
- systemui: move dock battery level views outside systemicons layout
- qs: initialize day temperature in livedisplay tile
- SystemUi: Respect shouldCollapsePanel when handling onClick.
- Fix statusbar dead spaces
- autobrightness: Fix the brightness dialog is not work when first enable auto-backlight
- Update APN List
- Inlcludes All bug fixes and performanced updates from cyanogenmod
- For More Information Track github activities
Download:
ROM: https://www.androidfilehost.com/?a=show&w=files&flid=10443
Gapps: http://click.xda-developers.com/api/click?format=go&jsonp=vglnk_143941180684420&key=f0a7f91912ae2b52e0700f73990eb321&libId=id97n6v601000n4o000DLo01g9wjz&loc=http%3A%2F%2Fforum.xda-developers.com%2Fgoogle-nexus-5%2Fdevelopment%2F5-0-2-hammerhead-resurrection-lollipop-t2987937&v=1&out=https%3A%2F%2Fgithub.com%2Fcgapps%2Fvendor_google%2Fblob%2Fbuilds%2Farm64%2Fgapps-5.1-2015-06-02-15-20.zip%3Fraw%3Dtrue&ref=https%3A%2F%2Fwww.google.pl&title=Hammerhead%20%5B5.1.1%5D%20%5BDevelopment%5D%20%5BPitchBlack%E2%80%A6%20%7C%20Google%20Nexus%205%20%7C%20XDA%20Forums&txt=%3Cfont%20size%3D%224%22%3EGapps%3C%2Ffont%3Elub http://gapps.cyanogenmod.pl/
Screeny:
post-69733-0-99959400-1439412101_thumb.p
post-69733-0-33616500-1439412313_thumb.p
post-69733-0-88681500-1439412329_thumb.p
post-69733-0-70866600-1439412340_thumb.p
post-69733-0-71888500-1439412355_thumb.p
post-69733-0-89427900-1439412364_thumb.p
Można też dodatkowo wgrać taki motyw jak na sreenach albo inne. Można pobrać stąd: https://play.google.com/store/apps/dev?id=8959388472725399421
