NeoCM Opublikowano 14 Maja 2015 Zgłoś Udostępnij Opublikowano 14 Maja 2015 [Redmi 1S] Sonic Open Kang Project [5.1.1] Rom oparty na najnowszym buldzie od Google, moim zdaniem jeden z najciekawszych romów. ROOTCWM/ TWRP najnowszeLista zmian:Various Bug Fixes Compared To Goggle AOSPMaterial Dark UI.Advanced Mode In Settings.Configurable Custom colours in Battery Saver Mode.On The SpotOn Screen Navigation Bar switch.Navigation Bar Left handed Mode in Landscape Mode.Configurable Navigation Bar Hight.Navigation Bar Button Colour.Materialised Toast Frames.Disable FC Dialogues.Materialised Text Select handle.Smooth Upload & Download Animations.Fix For Battery Status wakelockStatus Bar Left Clock.Customizable Battery icon.Status bar Notification Counts.Double Tap To sleep option in status bar.Status bar Brightness control.Quick Pull-downWeather above Quick settings.Quick Settings CustomisationsConfigurable Power Menu.Configurable Multi-user Accounts.Customizable device wakeup with home, volume buttonsCustomizable long press action and Double tap actionOption to reorient volume button when screen rotatesCustomizable lock screen slider short-cutsGlow-pad double tap gestureWake Lock BlockerCustomizable Navigation Bar and Navigation RingsCyanogen Mod Themes with customizable Styles,,Icons,fonts boot animation,sound packs,etcCustom Profile switcherExpanded DesktopCustomizable advanced Display with Scenario,night mode.Notification LightScreen CasterCPU and Memory Info In Settings About.Custom Volume StepsAscending Phone Ring TonesPrivacy GuardCaptionsMock Location and Mock SMSAdoptive Back lightBeautiful SOKP Fonts System Wide.Apex Launcher As Default Launcher for Time being.Own Custom DTS Audio System with support of Dolby Digital Plus customizable equalizer which can be used for system wide sound control( Will be Merged Soon)Inbuilt Metaon Powered Performance Boost By Spike LabMany More ..... Pobierz ROM i Gapps Wrzuć pliki na kartę pamięci Wyłącz telefon Uruchom go w trybie recovery Wykonaj pełne WIPE Zainstaluj ROM, potem GappsROM: http://sonic-developers.com/downloads/?dir=armaniGapps: http://gapps.cyanogenmod.pl xda: http://forum.xda-developers.com/redmi-1s/development/armani-t3067385 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
