NeoCM Opublikowano 4 Lutego 2015 Zgłoś Udostępnij Opublikowano 4 Lutego 2015 [Galaxy Note 2 N7100] crDroid 5.0.2 [CM based] Jest to rom oparty na CM 12. Wymagania:ROOTCWM/TWRP (polecam TWRP)Screeny:http://crdroid.org/?page_id=472 info o romie:crDroid Custom Features:Nav bar tweaks (on/off toggle and custom dimensions);Animated rotation tile;Wake up on plug;Development shortcut;Clock and time clickable in expanded status bar;Notification ticker;Quick unlock;PIN keypad shuffler;Custom lockscreen shortcuts;Answer calls with hardware home button;Status bar clock tweaks (right, center or hide clock with many dates formats to show. Custom colors included);Notifications counter;Volume keys wake the device;Ability to hide the alarm clock icon from status bar;Dialer Lookup;Profiles form CyanogenMod (new merges and lollipop style);Protected apps (using trebuchet launcher);Filter spam notifications;CyanogenMod SuperUser;Clear all button in recent panel with custom option (hide, top right or top left);Privacy guard from CyanogenMod;Quick settings pull down with one finger (right, left or off);Smart pull down;Configurable 0, 90, 180 and 270 degree rotation;Toggle to not allow quick settings on secure lockscreen;Brightness control through status bar;Double tap status bar sleep;Data activity indicators;Call blacklist support;Increasing ring tone;In call vibrations;Advanced reboot menu;Option to hide adb notification;Screen shot quick delete with confirmation;Long press back to kill with configurable timeout;Less frequent notifications sound;Advanced keyboard features (auto rotation with timeout, disable full screen, selector notification, show enter key, volume key cursor control);New Eleven music player and AudioFX from CyanogenMod;Status bar network speeds;AOKP system animations;Left handed navbar during landscape mode;App circle sidebar;Toast Animations;Media Scanner on boot behavior;Gesture Anywhere;LCD density;cLock; Sposób instalacji:https://www.youtube.com/watch?v=ZmOVMbMkQZc Pobierz:ROM: https://www.androidfilehost.com/?fid=95916177934522871Gapps: http://gapps.cyanogenmod.pl xda: http://forum.xda-developers.com/showthread.php?t=2738829 1 Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
zeuspl Opublikowano 23 Marca 2015 Zgłoś Udostępnij Opublikowano 23 Marca 2015 fajny rom,działa płynnie i szybko jedyny minus to za wielkie ikony menadżer pamieć jeden folder zajmuje pol ekranu Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Pawliniak Opublikowano 23 Marca 2015 Zgłoś Udostępnij Opublikowano 23 Marca 2015 Masz możliwość pokazania tego? Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
zeuspl Opublikowano 23 Marca 2015 Zgłoś Udostępnij Opublikowano 23 Marca 2015 <p>http://www.fotosik.pl/pokaz_obrazek/d2d11e50c0f3a251.html</p>I to jest jedyny minus. Reszta to już tylko plusy Cytuj Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
