[Nexus 6][LRX22G] Chroma – 01/26/2015 | Native LED Notifications | Dark MaterialUI
  • ROOT
  • CWM
  • Odblokowany bootloader
Info o romie:
Franco Kernel r10
Dark material theme (see screenshots tab or link below)
VomerTweaks Integration (coming soon)
Native LED Notifications (no need for Light Flow)
Status Bar Customization:
Battery Style (Icon Portrait/Landscape, Circle, Text, Hide)
Battery Percentage (Inside, Outside, Hide)
Clock & Date (Show/Hide, Color, Alignment, AM/PM, Show/Hide Date, Date Style, Date Format)
Brightness Control (long press status bar to change brightness)
Double-tap status bar to turn device screen off
Quick pull-down on right side to pull down tiles
Long press tiles for options
Clicking on clock or date on status bar opens up Clock, Calendar
Show/hide notification count
Quick Settings Customization
Show/hide brightness slider
Navigation Bar Customization:
Navigation bar height (including hide navigation bar)
Disable Search Bar in Recents Menu
Kill app back button
Clear all recents button (enable/disable)
Clear all recents location (top left, top right, top center, bottom left, bottom right, bottom center)
Clear all task (dismiss all task or ignore the foreground task)
Lock screen customization
Power menu customization
Advanced Reboot
Volume Rocker customization:
Wake device with volume keys when screen off
Long press volume up/down keys to skip track when screen off
Volume key adjustment sound (enable/disable)
Other:
A large number of optimizations and memory leak fixes
Expandable volume panel
Long press recents to swap back to previous app
Replaced AOSP Gallery2 with Material Design Apps
... and more (see changelog)
post-7223-0-58803100-1422433882_thumb.pnpost-7223-0-67029500-1422433912_thumb.jp
Pobierz:
Chroma 2015-01-26 | GApps | SuperSU | VomerTweaks
All Chroma Builds
Instrukcja:
1.       Pobierz ROM i Gapps
2.       Wrzuć pliki na pamięć urządzenia lub na kartę pamięci
3.       Wyłącz telefon
4.       Uruchom go w trybie recovery
5.       Następnie wykonaj pełne wipe systemu (cache, system, data, dalvik cache)
6.       Potem instalujemy kolejno:
·         ROM
·         Gapps
7.       Reboot
xda: http://forum.xda-developers.com/nexus-6/development/rom-chroma-01-11-2015-t3000003
