[Nexus 6][OFFICIAL]LiquidSmooth v4.0
Rom jest oparty na AOSP z dodatkami od teamu.
  • ROOT
  • CWM (TWRP najnowsze)
  • Odblokowany bootrloader ( o ile wymaga model)
Lista zmian:
* Sabermod 4.8.4 GCC Toolchain
* Kernel based on @franciscofranco kernel
* LCD KCAL control
* Disabled forced encryption
* Tweaked CPU governors
* Voltage control
* CPU overclocking
* FauxSound
* LiquidSmooth build optimizations
* Black UI
* Linaro and Code Aurora Optimizations
* Custom toast animations
* Option to disable screenshot noise
* Built in superuser options with Root access options
* Call blacklist options
* SMS rate limiting option
* Filter spam notifications
* Per app control for Lockscreen notifications
* Configurable 0, 90, 180 and 270 degree rotation
* Safe headset volume option
* Less annoying sound notifications option
* Option to use volume keys to control media volume anytime
* Option to custimize device hostname
* Option to not wake up device when charge is plugged/unplugged
* Volume rocker wake up
* IME switcher notification control
* Option to disable fullscreen keyboard
* Force autorotation on IME
* Option to force show enter key
* CM's Privacy Guard
* Increasing ringtone option
* Dark UI (primarily in Settings for now)
* Screen Density changer
* Statusbar clock customization
* Option to disable searchbar in recents
* Statusbar brightness control
* Double tap statusbar to sleep control
* Custom Lockscreen shortcuts
* Extra info about your device (About phone/tablet)
* Custom Liquid Logo in about phone/tablet
* Google bug report and ota removed
* Option to show kernel toolchain and other info by tapping kernel version in about phone/tablet
* Timeout and instant lock options added to slide unlock instead of just secure keyguard options
* Developer options enabled by default
* Navigation bar height control
* Show application package name in app info
* LiquidSmooth Stats and Updater added
* Partition size info
* Option to disable immersive messages
post-7223-0-09628700-1422433002_thumb.pnpost-7223-0-51361400-1422433019_thumb.pnpost-7223-0-89489500-1422433036_thumb.pn
Instrukcja:
1.       Pobierz ROM i Gapps
2.       Wrzuć pliki na pamięć urządzenia lub na kartę pamięci
3.       Wyłącz telefon
4.       Uruchom go w trybie recovery
5.       Następnie wykonaj pełne wipe systemu (cache, system, data, dalvik cache)
6.       Potem instalujemy kolejno:
·         ROM
·         Gapps
7.       Reboot
Pobierz:
ROM Download - v4 Nightlies
LiquidSmooth Kernel (flashable zip)
Flash newest SuperSU
(Flash to ensure TiBu and other root apps work properly.)
Download link for recovery-flashable zip of the old UI theme (will try to update weekly).
xda: http://forum.xda-developers.com/nexus-6/development/rom-liquidsmooth-v4-nexus-6-97-t2973469
