[Galaxy Note II - N7100] EmotionMIUI Note II V2.7 |MIUI V5| |Aroma| |Clean and Fast| Emotroid
Rom na bazie MIUI dla Note 2 od Emotroid.
Team godny polecenia!!
Info o romie od teamu :
Based on MIUI 3.9.27 from [urlwww.xiaomi.eu (Click to see Changelog MIUI 3.9.27)
Thanks to Trunk for his translation in spanish
Multilanguage packeg 3.9.27 adapted to 240 dpi, center clock,etc.
Added modem XXDME4 (highly recommended) and XXDMF1
MIUI Browser works well, no more FC
Enable GPU rendering for 2D operations thanks to mike1986
Init.d
Removed some applications
Improved signal and 3g
Improved GPS
Added Last Play Store, and Gmail
Improved speed of MIUI Launcher
Added new sounds
Increased volume of the speaker and headphones
speed of SD "1024"
Improved speed of all
RAM improved
Zipalign in realtime
Added several tweaks to improve fluency
Center Clock on status bar
modified multiwindows
Increase overal touch responsiveness
Made streaming videos faster
Increased quality of JPEG images
Added Bravia Engine
3-way reboot menu
Fixed Media Scanner (wakelock)
Added script to kill some processes
Added new settings
You can change lcd density from settings (thanks to xperiacle for his apk ui switcher)
All apks support multidpi (if you use the Samsung keyboard you will have to flash samsung keyboard 240dpi)
Fixed dialpad for 240dpi
Added Multidpi Play Store
Added more apks (cusettings, youtube,etc.)
Enable crt-off animation
Fixed 3-way boot menu
Fixed stweaks
Added small gapps
post-7223-0-50462300-1410934176_thumb.jp
Pełna lista zmian:
Added Perseus Kernel 36.3
Added all improvent of v2.6
Fixed other little bugs
TODO:
Multidpi
Crt-off Animation
Disable exchange security
Improve miui launcher
and more..
Changelog V2.6
Based on MIUI 3.7.5 from www.miui.es (Click to see Changelog MIUI 3.7.5)
Multilanguage packeg 3.7.5 adapted to 240 dpi, center clock,etc.
Added all improvent of v2.5
Changelog V2.5
Based on MIUI 3.6.21 (Click to see Changelog MIUI 3.6.21)
Multilanguage packeg 3.6.21
Added last stock kernel
Fixed stweaks
Fixed dialer on 240dpi
Added small gapps
Added MiHome 2.5.1-0625-alpha
Added all improvent of v2.4
Changelog V2.4
Based on MIUI 3.6.14 (Click to see Changelog MIUI 3.6.14)
Multilanguage packeg 3.6.14
Added new settings
Added all improvements from the previous version
And other little things that I don't remember
Changelog V2.3
Based on MIUI 3.5.24 (Click to see Changelog MIUI 3.5.24)
Multilanguage packeg 3.5.24 (Fixed in Aroma Installer)
Added Bravia Engine
3-way reboot menu
Changelog V2.2
Based on MIUI 3.5.10 (Click to see Changelog MIUI 3.5.10)
Multilanguage packeg 3.5.10 (In Aroma Installer)
Last Stock Kernel (Optional in Aroma)
Added Nadia Kernel V1.0 (Optional in Aroma) Here is the thread
Added Modem DXDLK5
Changelog V2.1
Based on MIUI 3.4.26 (Click to see Changelog MIUI 3.4.26)
Last Stock Kernel
Multilanguage packeg 3.4.26 (In Aroma Installer)
Added Spen Helper
Changelog V2.0
Based on MIUI 3.4.12
Last Stock Kernel XXDMC3
Init.d
Improved GPS
Added new sounds
speed of SD "1024"
RAM improved
New Theme by Ivanebdesign (Second Post)
Changelog V1.2
Control app extended (Center clock, etc.)
Added GAPPS
Added Multilanguage
MIUI Equalizer
Spen Helper
Modem XXDLK7 or DDDLK6
Efs backup
Flash player
Apps stock Samsung and others
Fixed Ui settings (Second post)
Changelog V1.1
Fix SU permissions
Added Emotion Wallpaper apk
Changelog V1.0
Based on MIUI V4 FINAL
Last stock kernel 4.1.2
Root
Deoxed
Zipalling
Init.d
Lite
Last compilation LORDSTENKA (Thanks)
Includes programs of MIUI
Multi langueges (Spanish too)
Improved translations
4 way boot menu
Multiwindows with all apps
All functions of Spen
Added Tweaks to improve performance
Improved GPS
Blue theme by Jcanonico (Second post)
Bootanimation By Ivaneb-design
Stock aplications of Samsung (Second post) (Thanks DeadSix17)
Stable, fluid and clean
Added new sounds
And little things that I don't remember
  • ROOT
  • CWM/TWRP
Pobierz:
EmotionMIUI V2.7 Aroma English
EmotionMIUI V2.7 Aroma Spanish
Samsung Keyboard 240dpi
ClockPackage Samsung 240dpi
Samsung Keyboard 320dpi
ClockPackage Samsung 320dpi
Instalacja:
  1. Pobierz rom
  2. Wrzuć go na kartę pamięci
  3. Uruchom tryb recovery
  4. WYkonaj wipe
  5. Zainstaluj rom
  6. Reboot
Theme!!!
Instalujemy z poziomu menagera plików
https://www.dropbox.com/s/7qljx0bbgn678zf/Full_Clean-By.Ivaneb-design_V_FINAL.mtz
xda: http://forum.xda-developers.com/showthread.php?t=2192641
