[Galaxy S5] X-Note TMT v.1.0 *True-Multidpi-Touchwiz* [4.4.2]
Zmodyfikowany Custom rom dla Galaxy S5
Jak widać ma dodatki z Note 3
  • ROOT
  • CWM/TWRP
  • EFS backup
post-7223-0-85335400-1397937664_thumb.jp
ROM wgrywasz na własne ryzyko!!
Info o romie:
  • based on latest G900F NCF samsung firmware
  • Rooted, busybox
  • Region unlocked
  • True Multi Dpi Touchwiz (work in progress) - ability to select your screen density (via X-Transformer app)- available parameters:
    -480 dpi (stock)
    -450 dpi
    -420 dpi
    -390 dpi
    -360 dpi
    -330 dpi
    -300 dpi
    -289 dpi
    + custom dpi selection
  • multi dpi modded samsung applications to have best fit at all density (work in progress but almost done)
  • Xposed installer
  • Xposed app settings module
  • Multi dpi play store
  • Ability to enable/disable the feature double tap on status bar to turn off the screen
  • Ability to choose the number of visible toggles coloumns (1------10)
  • Ability to show/hide toggle status indicators
  • Ability to show/hide toggle text
  • Ability to change color of active toggles
  • Ability to change color of dim toggles
  • Ability to change color of OFF toggles
  • Ability to change color of toggle text
  • Ability to change color of active indicators
  • Ability to change color of dim indicators
  • Ability to change color of OFF indicators
  • Ability to show/hide day
  • Ability to show/hide Speed Meter statusbar
  • Ability to show/hide Bluetooth statusbar
  • Ability to show/hide Sound Vibrate statusbar
  • Ability to enable/disable on the fly the infinite scrolling in TW launcher
  • Ability to enable/disable on the fly the wallpaper scrolling in TW launcher
  • Ability to enable/disable Clock View Select
  • Ability to enable/disable Clock Center Select
  • Ability to enable/disable Clock Right Select
  • Ability to enable/disable Clock AM PM Select
  • Ability to enable/disable Clock AM PM Small Select
  • Ability to enable/disable Clock AM PM Regular Select
  • Ability to enable/disable Clock Weekday Select
  • Ability to enable/disable Clock Weekday Small Select
  • Ability to enable/disable Clock Weekday Regular Select
  • Ability to change color of Clock
  • Ability to enable/disable Data Mode in power menu
  • Ability to enable/disable Airplane Mode in power menu
  • Ability to enable/disable Power Off in power menu
  • Ability to enable/disable Restart in power menu
  • Ability to enable/disable Emergency in power menu
  • Ability to enable/disable Accessibility in power menu
  • Ability to enable/disable CPU Widget on Dropdown
  • Ability to change color of CPU Widget on Dropdown
  • Ability to enable/disable Home Button Wake
  • ability to change battery icon on the fly (+100 battery types)
  • added face unlock security lockscreen (in lockscreen settings)
  • delete/restore bin/gsiff_daemon to save battery (via x-note app)
  • Device status "official" instead of "modified"
  • unlocked multi dpi play store credits @ MyLifeRocks10
  • Audio levels stock/boosted selection (aroma) + 3 audio level selection (via X-Note app)
  • Acdc sound mod (aroma)
  • Viper 4 android sound mod (aroma)
  • csc selection (aroma)
  • email client selection AOSP/SAMSUNG (aroma)
  • secondary symbols in stock samsung keyboard
  • 9 homescreens in tw launcher
  • Universal init d enabler (for stock kernel)
  • cpu monitor (via xnote app)
  • cpu spy (via xnote app)
  • multiwindow manager app - add any app in your side bar (credits @xperiacle)
  • 4 multiwindow freestyle mod - ability to open 2-3 or 4 app at the same time (via xnote app)
  • add custom shortcuts in notification panel
  • camera shutter sound option
  • prompt to exit from samsung browser
  • youtube ad away xposed module
  • greenefy app
http://www.androidfilehost.com/?fid=23329332407587562
Dla wersji G900F!!
  1. Pobierz ROM
  2. Wrzuć go na pamięć urządzenia
  3. W ustawieniach zabezpieczeń odznacz opcję reactivation lock in security settings
  4. Zrób kopię EFS Backup
  5. Wyłącz telefon
  6. Uruchom go w trybie odzysku (recovery)
  7. Wykonaj kopię zapasową (nieobowiązkowe)
  8. Wykonaj pełne WIPE systemu
  9. Zainstaluj ROM
  10. Reboot
xda: http://forum.xda-developers.com/showthread.php?t=2724138
