[Galaxy S Plus] KVT49L][4.4.2] MoKee OpenSource Project 44.2
Jest to rom na bazie Kit Kat!!!
Na najnowszej wersji od google
Info o romie :
  Cytat
  • Incremental updates
  • Native exFAT support
  • ListView animations
  • Multi window
  • Calendar - with lunar and solar calenders
  • Lunar calendar in lock screen
  • Task switching sidebar in recent apps (the list will increase if you install supported apps)
  • Bulk SMS recipients
  • Adjustable SMS font size
  • SMS sending delay
  • Smart dialing
  • Speed dialing
  • IP dialing
  • Custom carrier name
  • Network speed in status bar (upload and download!)
  • Built in timer in Apollo - determine when to stop playing music
  • MoKee NotePad
  • MoKee Setup Wizard
  • Active Display
  • HALO
  • Adjustable navigation bar height
  • Unique Power Saver functions!
  • Custom screen off animations
  • ** Not yet merged
    PIE control
    Auto hide status bar
    Smart capture
    Preview option in launcher (similar to the preview function in launchers found in Play Store)
    Many more! Since we are constantly adding new features, see changelogs to keep updated!
Co działa w romie:
  Cytat
  • Audio
  • Receiving and making calls
  • GPS
  • Compass
  • Proximity sensor
  • Wifi
  • Bluetooth
  • USB mass storage
  • HW accelerated gui
  • HW accelerated video
  • Camera
  • BLNv10
  • USB/Wifi tethering
  • VSync
  • USB OTG
  • Phantom key presses filtering
Nie działa
- aktualizacje OTA (jeszcze nie)
  1. Pobierz te recovery i je wgraj: http://forum.cyanogenmod.pl/index.php/topic/1690-galaxy-s-plus-cwm-twrp-by-adc-team/
  2. Następnie pobierz ROM i Gapps
  3. Wrzuć pliki na kartę pamięci
  4. Wyłącz telefon
  5. Uruchom tryb odzysku
  6. Wykonaj pełne wipe
  7. Zainstaluj ROM, potem gapps
  8. Reboot
ROM: http://forum.xda-developers.com/devdb/project/?id=1924#downloads
Gapps: http://d-h.st/PGT
xda: http://forum.xda-developers.com/showthread.php?t=2560485
  • 2 miesiące temu...
