[Galaxy S III Mini] [PORT][4.4.2][WIP] Beanstalk 4.4.200 Unofficial
Port ROM dla Galaxy S III Mini, na bazie K.K 4.4.2
Wgrywacie rom na wałsne ryzyko
Info o Romie:
  Cytat
CM based
Lockscreen background options (Color fill, Custom image, Transparent)
Customizable Lockscreen text color
Lockscreen rotation
Option to enable all widgets
Minimize lockscreen challange
Use widget carousel
Slider Shortcuts
Static Lockscreen shortcuts
Lockscreen button actions
LCD Density
Scroll elasticity options
Default App grip option
Custom Carrier label
Dual Pane options
Customizable boot animation (off, default, set your own bootanimation)
Custom original BeanStalk Wallpapers by skyliner33v
Custom BeanStalk bootanimation by skyliner33v
Status bar color and transparency
Clock and date options which includes color, location, style
Signal Styles which include color and text instead of icons, alternate GB signal layout, hide signal icons
Breathing SMS option
Battery styles - Includes specific colors and styles. Also includes battery bar
Do not disturb option
Show notification count
Pie controls (need to have lockscreen background set to something other then default to work correctly (dont ask why) )
Fully customizable navigation bar - Includes style, layout, color, nav rings, pretty much everything you can think of.
Quick settings color settings, tiles per row, Quick pulldown, text color
Notification shortcuts, behaviour, drawer style (customizable colors), toggle colors, longpress quicksettings icon to enable/disable toggles
Keyboard and input method options which include disable full screen keyboard and auto rotate
Kil app back button with customizable timeout values
High end graphic effects option
option to disable/enable vibrate on expand for notifications alerts
Low battery warning customizable options
Recents RAM bar fully customizable with color styles
Clock widget for LockClock including extra options to fully customize every feature of the lockclock
Build.prop MOD options to enable/disable tweaks as preferred
Less frequent Notification sounds options
CRT screen off/on options to specify how the animation shows
Enable/disable wake up on charge option
Superuser fully embedded into the build and accessed from settings menu
CM Performance options and features
About BeanStalk option with links to github source and facebook for beanstalk. Also links to my twitter and donate.
insane amount of edits/tweaks/fixes to make this build absolutely fly
option to use a fully themable MMS packages. You can access from mms - settings - theme settings
Numerous other options hidding throughout the build
Pobierz:
ROM: http://www.androidfilehost.com/?fid=23269279319200875
Gapss: http://d-h.st/PbA
Instalacja:
  1. Pobierz ROM i Gapss
  2. Wrzuć pliki na kartę pamięci
  3. Uruchom tryb odzysku
  4. Wykonaj WIPE (pełne)
  5. Zainstaluj ROM I Gapss
