[JB4.2.2][P6-U06][ HYD52ROM V1] [ Superfast , Stable , EMUIbase ]
Custom ROM dla posiadaczy Ascend P6
Wgrywasz soft na własne ryzyko
post-7223-0-63263700-1388323946_thumb.pnpost-7223-0-54572300-1388323972_thumb.pnpost-7223-0-21794400-1388323999_thumb.pn
◢ Info o ROMie od autora ◣
  Cytat
THANKS A LOT TO JEEKO FOR SUCH A NICE POWER BOOSTER
- Android performances improved at 360°
- Radically improved management ram on android (Lags...adios!)
- Script lightweight and revised to be adapted to this engine
- Improves a lot the graphics: of course Pure Graphic™HD, Pure Dithering Plus™ and... AOSPA 3.60 system tweaks
- Scan multimedia time drastically reduced
- Network Improvements, 3G experience even in 2G modality
- All SQlite database optimized
- Enable hardware features turned off by default for a better experience on entry level devices
- Greatly increases the score AnTuTu: Try it to believe it!!
- Reduces the startup time of Android
- A version for stock rom and one for CM, to squeeze any roms!
- Allows you to play ported games without lags
- Cleans the system every 24 hours, thecache every week and the Dalvik every month (cronos easter egg)
- Automatically Zipalign on each boot (sensitive to the user)
Battery
- Drastically decreased the drainage of battery
- Check the activities that consume too much battery stop them with PureWakelocks™
- When the phone is charging reduces system services for faster charging
- The battery is calibrated on every boot
- Disable animation of the system when the battery is nearly exhausted
- Improvements in build.prop as regards the part of consumption
Graphics, Screen, Images
- Enables a non-aggressive dithering to save CPU
- When you lock the device, the engine makes sure that the GPU is turned off
- Enables deep sleepalso in the bugged rom
- Parts of bravia engine
- Of course parts of CrossBreeder (credits to dev)
- Of course parts of Adrenaline Engine (credits to dev)
- Of course PureGraphics HD, even though I already told you
- Of course V6 supercharger
- Generates video entropy (like seeder)
CPU, Governors, I/O Schedulers
- Slightly improves the scaling of the frequencies (for better results you need a good kernel)
- Lightens the load on the CPU switching the workload to GPU rendering
- Enable the swap partition in Android (experimental)
Informacje dot. dźwięku
  Cytat
Clear sound
- No more track noise
- Beats™ Audio by Dr.Dre
- Audio Pure™ Control not to damage your hearing
- Also compatible with the headphones that don't support audio render of 60kHz
- Where possible, arrange for the conversion of the songs (in background) below 256 kbps to 320kbps
- During playback of songs / sounds make a soft frequency scaling to reduce noise and highlight the track
- It offers more powerful and closed bass
- Efficient even with stock headphones
- Improves a lot the audio call
- Enhance the speakers for playing music without headphones in high quality
I can not tell you everything What are you waiting for? Try it and find out what's missing features!!
Instalacja:
1. Musisz mieć soft na bazie B118CN
2. Zainstalowany TWRP Recovery
3. Pobierz pliki poniżej
4. Przenieś pliki na kartę pamięci
5. Zrób Wipe Factory Reset
6. Zainstaluj rom
7. Zainstaluj Gapss
8. Zainstaluj Enable USB
9. Reboot
Pobierz:
HYD52ROM-P6-V1.zip
Gapps
Enable USB
7. Wipe Cache Dalvik
8.Reboot
wątek http://forum.xda-developers.com/showthread.php?t=2570602
